by Dico » Mon 07.03.2011, 19:40
Started the Elan up yesterday morning for a run to The Peak District. Got around 3 miles from home and noticed the voltmeter gauge was on full, 16 volts. Rather than fry the battery I decided to limp home, keeping the revs as low as possible I managed to keep the gauge down to around 14 volts. Went to start the Elan this morning and the battery was absolutely flat. No life anywhere! I figured the battery had split or something. It hadn't, and I managed to charge it fully. I also played around with the wiring on the back of the alternator to check if anything was loose. All seemed OK. Bit tricky mind as theres such little room there. I had done an oil and filter change earlier in the week and figured I may have disturbed something in that area. Could a broken wire/ loose connector to, say, the regulator cause an increase in volts?
I've just been for a quick run now after the 5 hour charge and the gauge is reading 14 volts again, and even when I give it plenty of revs it sits at 14 volts!? I'll try again tomorrow morning and see if the power drains out again. Odd!
Any thoughts?
- Fool Boy Four - Founder
by GeoffSmith » Mon 07.03.2011, 20:53
If you disturbed any wiring to the alternator it wouldn't source power. Take it easy as it might be a sign of the alternator regulator pack misbehaving. This is a well known problem when the alternator is used infrequently.
NOT REALLY.
- Kitty Fiddler
by Dico » Mon 07.03.2011, 21:14
Has anyone ever sourced just the regulator pack do we know, and could it be a diy job to replace? (I may not even need the bleeder now!)
by dapinky » Mon 07.03.2011, 21:16
Dico wrote::lol:
If only some kind-hearted bloke had offered you one from his old alternator yesterday you wouldn't need to ask now
- LEC Administrator
by Dico » Mon 07.03.2011, 21:29
dapinky wrote:If only some kind-hearted bloke had offered you one from his
OLD alternator yesterday you wouldn't need to ask now
This is the reason I would prefer a new one Pinkers. Kind offer tho.
GeoffSmith wrote: Take it easy as it might be a sign of the alternator regulator pack misbehaving. This is a well known problem
by Andy_J » Mon 07.03.2011, 23:28
Yep, new regulators are available,I managed to source one for the alternator in my red elan, when it started to over charge. However although the regulator had blown, it turned out to be the rotor on my alternator that had failed and blew the regulator.
I will rout around my receipts to see if i can get the references for where i got the regulator from
90H BRG SE 48,000 Miles
Andy_J
by Dico » Mon 07.03.2011, 23:31
Cheers Andy.
Rotor? Do you mean the pulley? Mine seized on a few months back but i managed to free it off. Wonder if there's a connection.
by GeoffSmith » Mon 07.03.2011, 23:38
Lots of friction => lots of heat => RPCF
- Kitty Fiddler
by Andy_J » Mon 07.03.2011, 23:40
Hi Dico
The rotor is the centre part of the alternator that spins, the windings had failed on my alternator. I had an auto electrician who is a friend of a friend rebuild my alternator he diagnosed the rotor fault. I am still trying to hunt down a ner rotor.
I think the new regulator was only about £25
Andy_J
by Dico » Mon 07.03.2011, 23:50
Ah, cheers again.
I think I may need to raid my dads shed again and hunt for my missing alternator (I usualy blame Smithy for my missing parts).
I'm going to take it for a slightly longer run tomorrow and see how it goes. Thats if the battery hasn't drained again.
by Dico » Tue 08.03.2011, 08:08
The battery seems to have remained fully charged overnight
by HJ2 » Tue 08.03.2011, 10:09
Then.... regulator it is!
When you've got it out of the car anyway... why not a general overhaul including the regulator, brushes and bearings?
by Andy_J » Tue 08.03.2011, 10:23
Had a rake through all my receipts and I can't find the one for the regulator, but I am 99.9% sure it was one of these I got
http://www.woodauto.com/Component.aspx?Ref=VRG4672A
Andy_J
by Dico » Tue 08.03.2011, 11:41
HJ2 wrote:Then.... regulator it is!
But why did it drain overnight the previous night? Nothing was left switched on. The only thing I've done is fiddle with the wires on the back of the alternator, but to be honest nothing appeared loose. If it was out of the car I would definately have it refurbished, but it isn't.
I'm going for another spin in the car shortly. If all seems OK then I'll just leave well alone. I'll be paranoid on any kind of a lenghth journey.
Thanks for the details Andy.
by GeoffSmith » Tue 08.03.2011, 13:55
Chances are the regulator has discharged the battery because it was too hot. Get it fixed because it will probably happen again.
- Kitty Fiddler
by Dico » Tue 08.03.2011, 15:46
Cheers Geoffers. I've just been for an hours drive and the gauge didn't move from 13.8 volts
. Do you think it could happen again then?
by HJ2 » Tue 08.03.2011, 15:49
Could very well be temperature related...
by GeoffSmith » Tue 08.03.2011, 18:45
You may have been lucky but I'd keep an eye on the gauge until you're sure. A few hundred miles (or 3½ years in your case) should be enough.
- Kitty Fiddler
