GeoffSmith wrote:Phil, there may be different issues to the KnoxMotorSport's masterpiece on RHD cars without the front crash structure, so a UK equivalent would probably have to end up slightly different.
If Phil can get Piper interested, would you be willing to help in getting it off the ground Billy?
surfboardfiller wrote:At the moment I am unaware of any on the market so this is new ground.
Monty wrote:surfboardfiller wrote:At the moment I am unaware of any on the market so this is new ground.
It`s not new ground as stevo produced the Stiffyyears ago out of stainless. Not sure he still has the prototype so maybe worth contacting, worth noteing that Stevo`s version could not be used on cars with A/C
some pic`s here
Steve A wrote::D If someone developes a down pipe that increases the cars performance especially if they already have a modified exhaust,
and they can show how much it improves over a standard set up well that's just![]()
I'm sure there will be a lot of interest.
HJ2 wrote:I've been puzzeling about that for a while now... Are the speeds of the airflow that different between main flow and bypass flow?
Or is the seperate pipe after the wastegate only there to make it a little laminair before entering main flow again?
If so, a shorter pipe, without flex would be possible if flow straitheners are incorporated in the design. Less weight, same flow capacities
GeoffSmith wrote:... and no separation of the wastegate pipe.
steve matthews wrote:Fed down pipe by Knoxmotorsports.
Produced more bang for the buck with less boost.
This upgrade far exceeds the PCE.
Steve -loving the upgrade-
surfboardfiller wrote:List time
To guage an interest in a UK/Euro Down pipe, please put your name on the list by copying the latest list and paste into your reply, adding your name in the useual format.
Who is interested in a Performance down pipe (for Turbo cars only)?
We are looking at 2 possible products:
NOC: To fit cars with NO Cat or eliminator (S2 completely de cat or SE).
PCE: To fit cars with a piper Pre Cat Eliminator.
1. NOC - Phil (surfboardfiller)
2. NOC - Phil (surfboardfiller)
3.
