Steering wheel boss adaptor for Momo etc - Sold out!
Re: Steering wheel boss adaptor for Momo etc - Sold out!
Postby saska » Sat 23.04.2011, 10:34
dapinky wrote:Am i right in thinking you're just trying to fit an Elise wheel to the Elan?
If so, nothing magical is required there is (or should be) a write up somewhere on here - otherwise i can re-do it!
suspect the write-up is HERE
Tony
adw (at) saska.co.uk
saska
Postby dapinky » Sat 23.04.2011, 11:50
That'll be the mark I version - there are a few other 'hints & tips' somewhere - but it is still correct :D (Thanks Tony!)
Basically, the 'puller' required can be made up easily, as a standard 3-leg won't work - i took about 3 hours to work out how to do it without damaging anything, and 5 minutes to make the 'tool' - a further 1 minute had it all off the car and in my hands.
Postby Alan_C » Sat 23.04.2011, 15:47
Pinky is right. Take the old steering wheel off and once you have eyes on the original boss, you'll see that (from memory) the top part is held on with 4 screws, or it could be that the wheel itself is held on with 4 screws..... Remove this and the Else steering wheel will bolt straight on. I do have an Elise wheel in superb condition if you need one.......somewhere.
Alan_C
Postby texas2201 » Sun 24.04.2011, 08:32
Thanks guys that info is spot on just need to find a puller! Dapinky do you still have the tool you made up?
Alan I wish you had mentioned you had an elise wheel - I have just bought one on ebay :-( - looks in very good condition - I would rather have bought from someone on the forum.............
Postby bobbrown » Sun 24.04.2011, 09:58
I think these fit about £17.00
Going to find out as I want to get it out of the way to fit the metal monkey dial faces.
Bob
Pacific Blue N/A
bobbrown
Postby texas2201 » Sun 24.04.2011, 10:00
LOL Bob what are the Metal Monkey dials?
Postby bobbrown » Sun 24.04.2011, 10:45
similar to the lockwood dial faces but better quaility as they are cut from stainless steel
These are Nige's
I went for white background with red lettering but there are lots of choices for the colours
Pacific Blue N/A
bobbrown
Postby texas2201 » Sun 24.04.2011, 11:10
will look good - post a pic when they are fitted so we can see the end result
Postby dapinky » Sun 24.04.2011, 11:34
bobbrown wrote:I think these fit about £17.00
Looks the part - but about £17 more than mine!
Basically, if you remove the horn push cover (30 degree anti-clock bayonet fitting), then the 2 set-screws which hold the horn bits to the wheel (the 2 at 3 and 9 o'clock), take out the horn bits, then you will see how the wheel attaches to the colapsible spacer by 6 screws, which attaches to the boss by 4 screws.
If you have a posh puller like Bobs, then cracking job, just loosen the nut, apply the puller and take the whole thing off.
You need to remove the boss from the spacer, and attach it to the Elise wheel - job done.
Without a posh puller, and being a tight-arse, i got a length of 4mm thick steel, approx 25-30 mm wide, and cut just long enough to fit inside the diameter of the collapsible spacer.
drill a half inch hole in the centre of the bar, tack-weld (or even hold with blu-tack!) a suitable nut (about M10 or 12) to one face of the bar, over the hole. Hold bar inside spacer (nut away from you), screw a bolt into it until it meets the top of the steering column, tighten it until the seal cracks and it comes off in your hands! Job done.
It will probably bend the bar a bit, but it isn't going to break before it comes away.
Postby texas2201 » Sun 24.04.2011, 12:04
Cheers Dave I will give it a go or let the garage do it when they fit the new stiffer springs all round :-) along with the 6 point harness to the passenger side along with the new seatbelt to the passenger side
Postby surfboardfiller » Wed 18.05.2011, 23:03
I have one I bought from Alan in Error thinking it was a Boss for a Momo wheel not an adapter (I wasn't listening was I). If any one wants it for what I paid for it £50 + postage.
EDIT: Sold, thanks Steve! :D
surfboardfiller
Postby Steve A » Thu 19.05.2011, 15:01
:D You have a pm Phil
