Brit-Car-Nut wrote:Is there any chance your exhaust or cat are partially clogged? Seems to be a common cause of boot failure.
JonT wrote:Is the default state of the wastegate open or closed?
Does the positive pressure applied through the capsule open it or close it?
Caveats suitably noted.saska wrote:One of the things they suggest in EMK3 is to ventilate the WG actuator line to prevent the actuator from opening the wastegate and then checking to see if it makes expected boost.
If you try this to see if it will go above 0.6Bar then please be careful -- it may boost to 0.98Bar and fuel cut with an Everest and you'll eat some steering wheel.
If it does boost higher than the fault is either in the wastegate actuator piping, Boost control solenoid piping, BCS or ECU.
If doesn't boost any higher then exhaust blockage would be next thing to check IMHO
JonT wrote:
Anyone got a spare BCFV - even if just to test with?
Jon
JonT wrote:So a few thoughts
1) The BCFV has dodgy electrical connections. I've now cleaned the contacts with contact cleaner - not sure how else to check this - even if I borrowed an oscilloscope from work I don't think it would show anything unless boost was being generated
2) BCFV pipes are the wrong way round - don't think so looking at the manual (vertical pipe to intake, horizontal pipe from wastegate actuator)
3) BCFV is knackered.
Not sure if there's any way to test 3, although it must be doing something as I can get above 0.41bar normally. All of the piping was replaced while I was trying to chase the problem, so I don't think it's that. I don't think it's ECU as the symptoms were the same whether I was using the Everest or just the standard ECU?
saska wrote:Have thought about this one for a while. When you say you replaced all the piping, do you mean 'all' ? Specifically, the BCFV outlet hose to turbo intake at airbox. Apologies for questioning what you've already written -- it's not meant in a disparaging way. I suppose it is also possible the wastegate actuator capsule is duff (spring weak and actuating the wastegate too soon) but this smells more of a hose restiction/blockage to me. I can't recall an instance of anyone replacing the wastegate actuator and solving the fault. I also tend to think the BCFV isn't faulty as it either works or not and the fact you get more than 0.41 indicates it works -- seems more likely the pressure isn't being successfully vented to atmosphere which means the hoses.
. No elanscan - I wasn't holding out hope that this time it would actually be fixed so I didn't bother logging, but will do another run before long and log just to check everything is as expected, but gauge now sits above 0.75 at full throttle and the car feels more sprightly than before
