OZZY wrote:Can anyone identify which chip this is? Everest or Kilamanjaro etc
JonT wrote:Definitely looks like you have both Everest and BBR kit. I'd suggest the everest is the more elegant solution, but have no personal experience of the BBR.OZZY wrote:Can anyone identify which chip this is? Everest or Kilamanjaro etc
The chips are identical - it's what is programmed on them that matters. I think Alan only charges about £20 for a reflash - if you haven't already got an O2 sensor, it's worth fitting one and getting the 1499 map - makes for much more economical cruising. Mine has a couple of stickers on it to identify it (one from the original everest, then another when I had the 1499 map reflashed).
The switch on the centre console looks quite similar to my alarm pad (Clifford), although mine also has an LED fitted nearby.
OZZY wrote:I too have a clifford alarm, what does this pad do?
JonT wrote:OZZY wrote:I too have a clifford alarm, what does this pad do?
Clunky way of programming it post-install - eg to change options like chirping on arm/disarm, turning features on/off. It should have a pin-code with it which can be used to disarm the system if the remote doesn't work/is lost.
tigerdog wrote:Normally, bypassing the BCV applies full pressure to the wastegate diaphragm. Stock diaphragm/spring would therefore open very low, around 5PSI. Since you're getting much higher boost, something else is in play. Typically, this would be a needle valve or ball/spring arrangement that keeps full pressure off the diaphragm, delaying opening. In your case, though, it seems it's something to do with the restricted hose.
JonT wrote:Wrong way round. Bypassing the BCFV means there's no pressure to open the wastegate (as it takes the low effort path and vents back to the intake), so you'll get masses of uncontrolled boost. Equally if you block the pipe from the wastegate actuator to the BCFV, you'll only get 0.41bar. Putting a restrictor in is trying to crudely emulate what the BCFV does - ie a controlled leak to atmosphere to get boost above 0.41 bar without it being uncontrolled.
Nige wrote:Looks like a BBR kit (Brodie Britain Racing) set up to me, the plasic restrictor and Fuel cut defeater are typical of thers I've seen. It's probably been fitted from new and the general view is that they do what they say and do not seem to cause long term harm.
You also clearly have a mountain chip which does the same in terms of giving higher boost and incresed performance but is more elegant and maintains some of the engine safety features which the BBR overides.
The key thing here is you must not have both. At present because the Boost Solenoid Valve is disconnected (the hanging hose) the chip is wholly ineffective as that is what the chip controls. My advice is to remove the BBR kit which will need you to remove the white plastic restrictor, reconnect the Boost Solenoid valve as it should be, disconnect completely the fuel cut defeater on the bulkhead and ensure the Manifold Absolute Pressure (MAP) sensor is connected correctly as the FCD interupts the signal to this to fool it into seeing a lower manifold pressure than is the case.
and if you have a modified exhaust be ready for overboost fuel cut off, which will require porting the wastegateReturn to Turbos, Boost, and Intakes
