Driveshaft moves with wheel off, engine running, in neutral
Drivetrain problems
Postby madbilly » Wed 21.03.2012, 14:27
Hi,
I was just going to check the timing and found that the driver's side driveshaft was moving when the engine was running but the gearbox in neutral? This doesn't seem normal to me, what could be causing it?
Thanks,
Will
madbilly
Re: Driveshaft moves with wheel off, engine running, in neut
Postby epipete » Wed 21.03.2012, 14:41
Will,
I had a similar query when my brakes failed last year. Brit-car-nut allayed my concerns wiyh the following:
"Yes, the hub will spin when the engine is running and the gearbox is in neutral. The input gear is getting power and the close fitment of the other gears and heavy oil induce sympathetic motion. Be careful. It can hurt if you get tangled up in the moving parts."
So it's normal, don't worry!
Pete
Postby DeanG » Mon 26.03.2012, 20:27
Normal
DeanG
Postby madbilly » Mon 02.04.2012, 20:54
Excellent, thanks for the confidence boost!
madbilly
