steve matthews wrote:This is how I believe it works. I'm sure I will be corrected if wrong.
The standard system with 2" pipe "squish" pre-cat and main cat boosted to
.65. If you are getting .5 on the unreliable guage then you may be at .65 which is
stock. When your pre-cat or main cat began to break up the system was able to
flow more volume therefore .8. When you remove or alter the pre-cat or main cat
you achieve .8 to .9 to 1 bar or what is called overboost. Their are many threads on
this subject how to correct and how to use the full potential of our little turbo.
Hope this helps.![]()
Steve
Mel_Boss wrote:Thanks for all of your time and help.
This is very kind and generous of you and I appreciate it!
I sent an inquiry to cbrown as you suggested...
Steve
Mel_Boss wrote:Back from the weekend Monterey festivities and time to report. Thursday's primary cat R&R took less than 2 hrs with good results. It was filled with broken-up debris (cat guts) that were cleaned out, and the cat was welded back. The rattle is gone and boost response is pretty much as before the R&R, shoots to .6 and creeps to .75/.8 at rpm max. So for now, I am satisfied and plan to pursue obtaining a replacement cat for the future. I will report if I experience any problems like CEL failures.
Thanks to all for sharing their experiences and knowledge. John, I have not heard back from Bibs and will send another inquiry later today
and I don't like it. I need my turbo.
