surfboardfiller wrote:Thanks Tom!
Do you have a price for ceramic coating the inside of the pipe?
PiperRS wrote:Back on topic.
The first batch of downpipes has been completed! I have limited stock of the downpipes ready for dispatch. they come with a fitting kit which include 35mm Studs for the turbo as the OE ones are prone to snapping on removal.
These are available now direct from ourselves, for £190 +VAT. They are stainless steel 2.5" bore downpipes.
Please contact our sales team for more information. sales@pipercams.co.uk or call us on 01303 245300
HJ2 wrote:The Lotus design does NOT have a separate wastegate traject like the Knox design. It does however have a small deflector directly after the wastegate flange that directs the flow of the wastegate downward. The Piper one does not have any of these features.
I am currently in the process of installing a Piperdownpipe as i desperately needed parts to replace the damaged sections and it is now ready available, so for me... a puzzle for beginners and i am happy with it.!
It's all about budget, and the best bang for the buck.
I'll post some pictures later on. I hope to do a testrun tomorrow![]()
I would be very interested in any feed back from someone who has got a downpipe on their car
lansledj wrote:Questions from the non mechanic![]()
1) will this fit with any exhaust ? I assume so as its just replacing the section as per Phils picture
2) does it matter if the whole exhaust isn't 2.5"? I have a 2" stainless system I think at present
3) could this cause overboost ? at present i don't suffer overboost and would need to pay for someone to do the wastegate if it did
Steve A wrote::? Question:
Is the down pipe a direct replacement that will conect to a standard exhaust ?
i.e is the exit of the down pipe the same orientation and length as the catalyst housing (the big cast lump we're trying to replace)
or is it only designed to fit the Piper system ?
PiperRS wrote:Steve A wrote::? Question:
Hello,
Our downpipe will replace the stock cat pipe, and will fit to either our exhaust system or the standard lotus system (and in theory a Peco or Quiksilver) This means that it can also be fitted at a later date and does not have to be fitted when the system is changed, and here is the pipe in question, posted here first, just for you guys![]()
paulsmithmk wrote:
so I could fit this to my S2 and have a totally new system - am wondering if I should have odered after all now?!!
