Radio aerial
Radio aerial
Postby Big_Al » Mon 03.09.2012, 21:32
Hi - does anyone know what car the aerial comes off ? Or is it a specialist Lotus part.
I am in the UK
Big_Al
Re: Radio aerial
Postby ashm » Tue 04.09.2012, 08:27
These are hard to find now, as the last remaining few from Lotus stock were bought up by members here in the last year or so. Do you need the actual aerial mast or also the base unit?
Adam
ashm
Re: Radio aerial
Postby Rice crispy » Tue 04.09.2012, 08:30
The were made by blue spot (blaupunkt) iirc. the thread on them is different to most others. There was a group buy for the last of them a while ago and Paul69 picked up the last 3 a week or 2 ago from Lotus and I know he has passed 2 onto other members. if its the rubber near the base that has fallen off you could always put a piece of shrink tubing on its place.
Rice crispy
Re: Radio aerial
Postby Big_Al » Tue 04.09.2012, 09:00
Hi and thanks for the responses
Its the bit you screw out (the bit you see above the wing). Previous owner used to take it off when putting car cover on and lost it !
Big_Al
Re: Radio aerial
Postby paulsmithmk » Tue 04.09.2012, 16:04
If it's anything like mine the reception is very bad anyway so new arial may be worthwhile - if you are wanting to stay original and its the same as on an S2 you can have mine once I find a replacement!
Big_Al wrote:Hi and thanks for the responses
S2 Number 640
paulsmithmk
Re: Radio aerial
Postby alan e » Tue 04.09.2012, 16:54
The complete aerial you need is a bosch 7 691 270 001 i have one if you need it but they are not cheap i got 2 sent from canada last year and only used the 1, pm me if you want to know the price.
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Re: Radio aerial
Postby FredFlanagan » Thu 06.09.2012, 08:52
They are available again....I just bought one two weeks ago from SJS. Cost £39 plus post.
FredFlanagan
Re: Radio aerial
Postby Peter D » Thu 06.09.2012, 21:41
That's only the mast, base not included.
Base is obsolete, I asked around with some Bosch colleagues in Germany.
(I work in Electrical Drives division @ Bosch, as project engineer wiper blades)
Peter D
Re: Radio aerial
Postby TrevorB » Fri 07.09.2012, 20:27
I have old aerial where the rubber covering over spring is worn away but otherwise in perfect working order, can post photo if you want? Let me know via here or pm. :D
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Re: Radio aerial
Postby Big_Al » Sun 09.09.2012, 20:32
Thanks everyone - have now got one :D
Big_Al
