Engine stops running
Postby Foxy » Tue 04.09.2012, 20:13
Guys
I've got a problem whereby the car will start from cold no problem. You can drive normally for a mile or so then it cuts out. When it cuts out the engine management light is on and it wont strt again until you've left it for 10 mins or so then it will start and get you another mile or so before stopping again.
Any suggestions as to possible causes welcome. Thanks in advance.
Foxy
Re: Engine stops running
Postby GeoffSmith » Tue 04.09.2012, 20:29
Do you have a paperclip? This might help.
Postby RayD » Tue 04.09.2012, 21:39
Welcome,
It’ll be interesting to see the result of this extreme case considering they all start better from cold than from normal operating temperature.
Presumably, it would cut out if you left the car stood ... it has nothing to do with driving it?
Will it go up to temperature in Service Mode without cutting out?
Have you checked the Tickover
Ray
RayD
Postby Foxy » Tue 04.09.2012, 21:52
Thanks guys. Plenty to check there. Thanks a lot. I'll let you know how it goes.
Foxy
Postby Foxy » Tue 04.09.2012, 22:28
Right. Paperclip test method reveals no fault codes. Just flashes 12. It has been sitting for several days without the battery connected. Would that clear any codes that were logged?
Foxy
Postby Tannerman » Tue 04.09.2012, 23:04
Sounds like a fuel issue to me...Either the fuel system is loosing pressure via a leak or a faulty fuel pump.
I am sure someone will tell you to do the wiggle test that usually sorts out anything from flat tyres to broken windscreens LOL
good luck
john
Lotus Elan M100 1990 (red
VW Tiguan R Line
Ford Transit Jumbo
Toyota Celica 25 th anniversary model
Tannerman
Postby ccb056 » Wed 05.09.2012, 01:45
could be a super clogged exhaust?
ccb056
Postby Foxy » Wed 05.09.2012, 09:20
Tannerman wrote:Sounds like a fuel issue to me...Either the fuel system is loosing pressure via a leak or a faulty fuel pump.
good luck
john
Thanks John
I wondered myself if the fuel pump was intermittent, but wouldn't there be a fault code logged in that case. As I say it's sat for weeks with the battery disconnected. Would that have cleared any codes that were there?
Foxy
Postby theelanman » Wed 05.09.2012, 09:49
mine has done this.....
CTS (coolant temp sensor) had gone......therefore the ECU had the engine at -39deg C so was basically overfuelling....
flooding the engine.....then taking 10 mins or so to evap and start again......
I suggest you buy the esprit version if it is the CTS......
the elan version is ~£60 the esprit version ~£15.....and theyre exactly the same.... :roll:
Postby theelanman » Wed 05.09.2012, 09:51
Foxy wrote:It has been sitting for several days without the battery connected. Would that clear any codes that were logged?
.....yes.....not have it connected to a battery will clear the fault codes.....
you'll have to repeat your fault..... :(
Postby dapinky » Wed 05.09.2012, 10:09
theelanman wrote:.......I suggest you buy the esprit version if it is the CTS......
And the Nissan version is just £8 on ebay
(the part number on the box i got mine in says WS1037, made by FuelParts)
Postby Foxy » Wed 05.09.2012, 20:50
Thanks a lot guys. I'll change the temperature sensor first (got to be worth a shot at £8) and take it from there. I'll also run it again and see what (if any) fault codes reveal themselves.
You guys are great!. I'll let you know.
Foxy
Postby Foxy » Tue 25.09.2012, 19:47
Hi Chaps
Finally had a chance to run the engine up today. It ran for nearly an hour before cutting out. Checked for fault codes using the paperclip method and no codes stored.
It has now stood for 4 or 5 hours but it will not start. I've checked for ignition and there is a spark, however when turning on the ignition there is no sound at all from the fuel pump. I've exposed the top of the fuel tank, and there is a three pin connector for the fuel pump and tank sender. One of the connections is earth i assume, and the other two are live feeds. One of the wires shows about 10.5 volts with the ignition on, and i suspect thats the sender connection. The other one shows next to nothing, so I suspect there is no power getting to the pump.
Any suggestions where I go from here?
Foxy
Postby RayD » Tue 25.09.2012, 20:33
You will know this already but ... the fuel pump fuse is number 3 in the main fuse box ahead of the passenger side door hinge
Ray
RayD
Postby Foxy » Mon 08.10.2012, 15:57
Just to let you lovely people know the problem is solved. It was an intermittent fuel pump relay.
Cleaned all terminals and re-fitted. Job done.
Thanks to you all for your help!!
FOXY
Foxy
Postby RayD » Mon 08.10.2012, 17:18
Well done,
Ray
RayD
