cam angle sensor
cam angle sensor
Postby marcos » Sun 05.04.2009, 16:43
when they will be out of stock from LOTUS : http://uk.farnell.com/honeywell-s-c/2av ... dp/1470597
you also find them on BMW R1100RT motorbike.
marcos
Re: cam angle sensor
Postby luluchiboy » Mon 28.09.2009, 14:50
where can you find this again that is in stock? I live in usa. and desperately need one.
luluchiboy
Postby GeoffSmith » Thu 01.10.2009, 01:39
Do a Google search on 2AV54 - there are plenty of suppliers in the States including Farnell's partner Newark.
Postby nitroman » Sat 03.10.2009, 00:29
Tat's a GREAT catch, truly. If the picture is correct it's supplied without the backing-plate though. That means you'd have to drill out the rivets from your old one and attach it to this new unit.
nitroman
Postby DeanG » Sat 15.09.2012, 00:14
It appears that 2AV54 is no longer available and has been replaced by BBHME56.
They are avalilable at http://www.bbautomacao.com/products.asp?cat=14
1pc for $ 50.00, 25-pc pack for $ 250.00 ($ 10.00/pc), 100-pc pack for $ 690.00 ($ 6.90/pc)
Time for a group buy?
DeanG
Postby Brit-Car-Nut » Sat 15.09.2012, 02:18
Or GBP15.00 + VAT at Lotus Aftersales: A100E0102S, HALL SENSOR ASSEMBLY, 1400 still available.
See viewtopic.php?f=3&t=21104
Postby rmsmall » Sun 15.07.2018, 16:41
The bearing on my cam angle sensor just went bad. I found a new one available at IsuzuPartsCenter.com for $121.15 by searching 8011038181 -the Isuzu part number. I've ordered the part and will update this post when it gets here.
It is called a "Sensor cam angle, w/turbo". It fits a 1991 Isuzu Impulse RS.
My daughters let me drive once in a while!
rmsmall
Postby wayne » Tue 17.07.2018, 14:46
rmsmall wrote:The bearing on my cam angle sensor just went bad. I found a new one available at IsuzuPartsCenter.com for $121.15 by searching 8011038181 -the Isuzu part number. I've ordered the part and will update this post when it gets here.
Would love to know if you ever received this part from them. I asked about it a few months ago and was told it was no longer available. Same email back today.....
Hope that they managed to find one for you.
http://www.elanm100.com
wayne
Postby Brit-Car-Nut » Tue 17.07.2018, 20:47
New Cam Angle Sensors have been unavailable from normal suppliers in the US. They occasionally show up on eBay, but none in the last 6 months or so...
Lotus still show A100E6020H as available but £303.27 is a bit steep...
Postby rmsmall » Sat 04.08.2018, 21:59
:agree: Sorry for the late response but, yes, there are no new CAS units available in the USA. I checked extensively with dealers and others. Maybe Korea if you have a connection.
This is a problem for me as I need to sell my Elan in the next few weeks as I am moving to London and my CAS is noisy and I can't figure out why.
I'll put my car up on this site in the next few minutes.
rmsmall
Postby Brit-Car-Nut » Sat 04.08.2018, 22:32
eMail sent
