Hammy360 wrote:Hi Im brand new here so I was hoping someone can help. Im looking a buying an Elan with a 'stuck' turbo. Is its just a case of getting another one and bolting it on or is there something else that could be causing?
Pascal wrote:Hello,
i am still investigating why my turbo doesn't give what it used to ( maxi 0,5 b , i had 0,65 and more power for sure a month ago).
i looked at the "wiki for wastgate wiggle" and unfortunately i did not manage to take the shield off.
BUT !
at least, i managed to unscrew the 3 screws of the capsule frame, moved this bow part and noticed that the rod was moving without effort.
then , put back the bow 3 screws in place .
If you have experienced that, you know this third screw down there ... you can reach this place only if you have flexible steel fingers, 10 ' ' long.
I managed to put the screw relatively easily, and that is something that could help someone else :
first : shaping (grinding) a flat wrench to have only the necessary shape to screw.
second : gluing with araldite a simple thin string 15 '' long , on the head of the screw.
after placing the screw in the wrench, only a bit of tension on the string gives a good control of the screw in the tool.
of course, the screw will fall as usual at least once, but the string is then the good friend to have it back immediately in hand, and loose no time.
That way, it was easier to put the screw than remove it.
Well , still 0,5 bar ...
Pascal
