chris.t wrote:A duff coolant sensor can cause massive over fuelling. But that should give a fault code.
rip wrote:chris.t wrote:A duff coolant sensor can cause massive over fuelling. But that should give a fault code.
Only if it is out of range. (I believe it can cope with climates as cold as -40c).
I ran Elanscan once with a non-runner when warm to find that the coolant sensor was reporting -37c IIRC & I had just driven there with my roof down! The CEL was not on. Engine ran for about 1 minute from cold before cutting out.
Brit-Car-Nut wrote:I don't trust the error code storage feature of the ECM. I read way too many posts where people have huge issues and no codes are stored.
I think the designers wanted to keep it more like a hunt and seek game...
Brit-Car-Nut wrote:I assure you I am not hoping it is a HGF. Just suggesting things to check to get a better understanding of what took place. I know the coils are new, but didn't they get soaked when the header tank burst a few weeks ago? Any chance they need to be removed and all connections including the base assembly get a good cleaning?
superbad wrote:Brit-Car-Nut wrote:I assure you I am not hoping it is a HGF. Just suggesting things to check to get a better understanding of what took place. I know the coils are new, but didn't they get soaked when the header tank burst a few weeks ago? Any chance they need to be removed and all connections including the base assembly get a good cleaning?
This set of coils has never been wet, they were replaced after the header tank fiasco. Anyway, here's hoping it's just a bad O2 sensor or something similarly easy. I'll report back when I'm able to collect some data.
Users browsing this forum: Bing [Bot] and 1 guest
