20mm as suggested by most
whippit wrote:i have a 2.5 with a precat eliminator, switcher , ported to 21mm never had overboost with this set up,
i had overboost with just the exhaust fitted, i fitted the chip and it helped, its worth a go doesn't take long
HJ2 wrote:Hmmzzz.. It's only in the top range that the overboost occurs. You can see the pressure slowly rise till cut-off level and the curve is already flattening or better at the top. So the system being to slow to respond.... i don't think so.
steve matthews wrote:Take the pre-cat out of the equation.
Steve
Users browsing this forum: Apple [Bot] and 1 guest
