Have had difficulty starting my car and not running correct under load suspect coolant temp sensor for ECU as a scan showed a negative reading have replaced with 330ohm resistor and now seems to run alright at normal temperature.
Am going to order a new sensor tomorrow any other suggestion at what I should be looking at, should mention that the car has always been difficult to start just more so now with this fault and not running right under load.
Have attached a scan with the temp sensor replaced by the 330 ohm resistor
Any advice appreciated Terry
could anyone also tell me what the dial REF is and what it should indicate in elan scan as this dial does not move when connected to my car
