Readit wrote:Thanks for that Rob and John, From the tyre size calculator they suggest that the percentage difference between the new and old circumference would be the increase or decrease of power to the wheels, thus the acceleration. I wonder if it is as simple as that.
Readit wrote:The largest 15 inch x 205mm tyre circumference or the smallest gave a percentage distance covered difference of nearly 20% which would theoretically increase the power to weight ratio by 20%.
rip wrote:Readit wrote:The largest 15 inch x 205mm tyre circumference or the smallest gave a percentage distance covered difference of nearly 20% which would theoretically increase the power to weight ratio by 20%.
I know what you mean, but you're using the wrong terms.
Fredjohn wrote:Putting in a different diff would have similar effect as changing tyre profile.
theelanman wrote:Fredjohn wrote:Putting in a different diff would have similar effect as changing tyre profile.
surely if that was the case then why invent another diff when all you needed to do was change the tyres....
is the diff not 'geared' basically?.....3.55 or 3.7...convert the input from the prop into an output from the diff to the drive shaft......
the speed at which he drive shaft rotates doesnt change
Fredjohn wrote:theelanman wrote:Fredjohn wrote:Putting in a different diff would have similar effect as changing tyre profile.
Yes it does: assuming a constant prop speed, the drive shaft speed will change if you put in a different ratio diff. Or viewed from a constant road speed you would need more or fewer revs for different ratio diffs. Thus altering the acceleration profile.
The overall wheel diameter changing also effectively changes the gearing. Hence the original question.![]()
, which dapinky thoroughly answered before I chipped in without having read his post!
theelanman wrote:is the diff not 'geared' basically?.....3.55 or 3.7...convert the input from the prop into an output from the diff to the drive shaft......the speed at which he drive shaft rotates doesnt change
Readit wrote:Rip, I agree I am probably not using the correct terms, but if Lotus geared a car to do nearly 140 MPH in top gear I do not think it is economically geared for 70 MPH. I love the Elan's acceleration between 70 and 90 MPH, it seems that no time elapses between the speedo changing from one speed to the other. but we are talking about exceeding UK speed limits even at those relatively low speeds.
Readit wrote:A further thought, fitting a Mountain Chip to increase performance must increase fuel consumption and strain on the engine, I would be interested in your views on where the difference is on the driveability.
)Users browsing this forum: No registered users and 3 guests
