Enclosed rear number plate cover
Postby m100sandra » Thu 27.02.2014, 12:14
I fancy putting the enclosed rear number plate panel on my Elan, but just wondering if i have everything :?: I think i have the complete panel? and a pressed No plate so hopefully no warping of a Perspex plate, So without having the original one removed yet ime thinking is there something missing on this set-up at the back for the no plate to stick to?
Just thought it best to ask in advance before i get the standard one removed :?
m100sandra
Re: Enclosed rear number plate cover
Postby theelanman » Thu 27.02.2014, 13:24
you should have a black box with lights in the sides as part of the car....
this has shaped vertical edges which follow the line of he rear lights
the cover plate fits to this.....
the number plate fit to the vertical face of the recessed black box.....
I think that's what you mean
as far as fixing the cover goes...it appears someone has drilled yours for screwing on....most were on a rubber/foam gasket which rotted and fell off......or for a fix which takes a lot of shifting (unless you get a very sunny day)...sikaflex it..... :-D
as for fixing the number plate......my original plate was fixed using std numberplate screws into the metal body
since replacing the plates on mine I have used sikaflex......
Postby m100sandra » Thu 27.02.2014, 13:58
Mine currently as the plastic recessed number plate plinth at the mo, the idea is to fit the early eclosed cover (I think it looks nicer) Black box with No plate lights :? :? i am missing this part :?:
m100sandra
Postby Dave Eds » Thu 27.02.2014, 14:41
Will it be legal?
How old is your car?
Postby theelanman » Thu 27.02.2014, 15:15
not sure about the back plate as Ive never taken mine apart.....
you seem to have the metal frame so I guess the backing could be just the body of the car......
not sure about the lights but theyre on the same location on both cars.....just behind the screen and frame on the early version and in the plastic on the later....
Postby theelanman » Thu 27.02.2014, 15:17
looks like you have it all......
just cant see anything different with the lights
Postby Rambo » Thu 27.02.2014, 18:33
Dave Eds wrote:Will it be legal?
My thoughts as well Dave. I don't think they were legal on a J plate :? When was your car manufactured and 1st taxed Sandra ?
Postby theelanman » Thu 27.02.2014, 18:37
I don't think they were ever made illegal.....
if they were then those with them would have to change them and lotus would have had to recall.....
they were revised as people used to get pulled by plod as they'd steamed up and you couldn't see the plate
Postby theelanman » Thu 27.02.2014, 18:38
IIRC.....they were never 'gatso' covers either......
Postby rip » Thu 27.02.2014, 21:34
theelanman wrote:I don't think they were ever made illegal.....
I suspect you are correct about that.
theelanman wrote:if they were then those with them would have to change them and lotus would have had to recall.....
But I don't think you are about that.
Seat belts are compulsory...but not on cars which were never built with them.
Same for rear seat belts. These became compulsory in the 80's. Even though the mounting points for them were included in earlier cars, they do not need to be fitted.
Sequential horns were made illegal in 1972, but cars built before can use them legally.
Cars which had catalytic converters fitted when new must have them for the MOT, but those which never had them do not need them retro-fitted.
Sandra: why do you want the older style covers? If you have read that they are gatso-proof then think again. I got zapped through one.
They steam up very badly & it is technically illegal to drive with them like this. It is also illegal to drive with plates so dirty you cannot read them but I see loads of cars like that in the winter.
The humidity & heat causes plastic plates to ripple after a couple of years & they look terrible like that.
Postby m100sandra » Thu 27.02.2014, 22:41
[quote
The humidity & heat causes plastic plates to ripple after a couple of years & they look terrible like that.[/quote]
I just like the look of them against the later plastic cover and they are different against the norm, more exotic :-) , Looking at some of the older posts, I have bought a pressed aluminium plate which will hopefully be OK, the steaming up as me a little worried :( Any recommended fixes for this :?:
Ill be hanging onto the original one though so I can always revert back.......
m100sandra
Postby Dave Eds » Thu 27.02.2014, 22:44
Yeah get a greenhouse heater! :wink:
Postby dapinky » Fri 28.02.2014, 09:09
Sandra,
There are 2 schools of thought on the steaming-up issue.....
...some drill a small hole at the base of the unit so water can escape....
...others seal it up well, so no water can get in.
I sealed mine up with silicone on all joints and screw holes - it was fine for 3 years then slowly allowed some moisture in.
I will remove the perspex cover (on a dry/non-humid day) and re-seal it - once we get a dry day :roll:
Postby Rambo » Fri 28.02.2014, 11:05
Personally, I think the lines of the car look nicer with the perspex cover. In the later models without it, it looks very much like Lotus forgot something :!:
And if it makes it a bit harder for the scamera's or Plod to read the no. plate when you're giving it :burnout: .................... ;-)
Postby Enright » Wed 19.03.2014, 16:01
I always wondered about the idea of a button on the dash operating a CO2 fire extinguisher in the boot - purely for emergencies you understand. Oops, have I posted in the wrong section? Silly me... :wink:
Postby dapinky » Wed 19.03.2014, 17:48
.... or just leave a bit of a chamois hanging out of the boot (purely to dry it off, of course)......
Postby stu123carp » Tue 16.09.2014, 18:17
Hi
Did you ever fit it? If not I would be interested in buying the Perspex cover as I've just broke mine :(
Regards Stu.
stu123carp
