Tunnel trim edge curling
Postby Squirtydog » Sun 16.03.2014, 21:19
Has anyone found a solution for this? Something just to neaten it up.
I was wondering if the edge could be covered with something like this.
Ideally a more plain texture though.
Ian
Lotus Elan M100, BMW i5 touring, 420i
Several guitars and a couple of cats
Squirtydog
Re: Tunnel trim edge curling
Postby Jeemy » Mon 17.03.2014, 14:32
Thats exactly what I planned to do to mine. Woolies have some different styles I think.
T: 0800 084 3084
M: 07391 295 146
Jeemy
Postby Rob P » Mon 17.03.2014, 15:16
I am currently in the process of reviewing the internals of the Lotus Elan and have used these guys when doing work on the Classic Mini's, they have a few options that might be usable here
http://www.phoenixtrim.co.uk/
simplify and add lightness
Rob P
Postby Squirtydog » Mon 17.03.2014, 20:24
Thanks both.
Ian
Squirtydog
Postby Squirtydog » Thu 20.03.2014, 18:56
Found this today during a tidy up.
Just a piece of plastic paper binding.
Attaches easily to the trim edge.
If this was in the same shade of grey or red like my carpet, then it would tidy the edge up nicely. It is the front portion under the dash which is curling, but you get the idea.
Firstly... Thoughts?
Second... Anyone know how to get hold of more than an A4 length? Can't be too expensive and is readily removable if it looks naff so may be worth a try.
Problem with edge trims for cars is that they seem to struggle with a 6mm thick edge.
Ian
Squirtydog
Postby Squirtydog » Tue 17.06.2014, 21:04
I have looked at quite a few automotive binding profiles and found them all to be a bit bulky, surface textured and not ideal. The solution above is what I am going for.
I have found these guys who supply the paper binding as pictured above in suitable lengths. However their website indicates package quantities of 100. I am hopefully going to get a sample of 8mm and 11mm to try. If I can get a lower quantity in black, is there any interest out there? The result really is as tidy as the picture above.
Ian
Squirtydog
Return to Interior
