Elise steering wheel
Postby andpap » Thu 10.07.2014, 18:47
Can someone kindly advise whether an elise s2 steering wheel will directly replace original elan s1 wheel?
Also will the horn work?
Please excuse my ignorance!
If not what replacement wheels will fit?
Many thanks.
andpap
Re: Elise steering wheel
Postby esprit888 » Thu 10.07.2014, 20:24
Yes, its a direct fit, you do need to grind or file down the auto cancel nub from the Elise hub though, Horn also works.
andpap wrote:Can someone kindly advise whether an elise s2 steering wheel will directly replace original elan s1 wheel?
Many thanks.
esprit888
Postby andpap » Thu 10.07.2014, 20:51
Great thanks for info.
Do you know if it is the same diameter or smaller? ( the wheel itself )
andpap
Postby cliff » Thu 10.07.2014, 22:20
Didn't need to grind anything down.
The Elise wheel is smaller.
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
Postby esprit888 » Thu 10.07.2014, 22:55
I sure did, could be that it was replacing the airbag wheel, which you don't have ? (I will post a pic once the site accepts them again)
cliff wrote:Didn't need to grind anything down.
esprit888
Postby epipete » Sat 12.07.2014, 09:38
:agree: me neither :burnout:
Postby esprit888 » Mon 14.07.2014, 00:43
The reason being you lucky buggers on tother side a pond don't have the airbag clock spring gubbins to get in the way:
esprit888
Postby Enright » Wed 30.07.2014, 21:35
andpap wrote:Fitted my elise steering wheel which, as per your posts was a direct fit, so generally very pleased.
I was wondering if anyone can recommend a leather wheel cover that would fit the 12" rim just to make the wheel feel a little thicker-
I have had no luck finding one that size, or possibly a leather wrap?
Any advice gladly received!
You have a PM.
Return to Chassis & Steering
