Plugs are fairly sooty, but not totally black (more brown on one side of the insulator).
I have checked the compression with the engine hot (just after radiator fans switch off) and got consistent readings of 185psi on all cylinders, which seems healthy.
The CO pot is set to 500 Ohms, I have tried turning it down to 270 Ohms and up to a few kilo Ohms but the car starts the same.
The Engine Management CTS appears to be below 200 Ohms when the engine is hot, I will have to check it again when cold, but the trend is negative with increasing temperature.
One interesting point perhaps is the behaviour of the dash while cranking - alternator light flickers and Volts gauge dips to just under 10 V. Probably normal, but the cranking is great - quite rapid.
Next thing I guess is to acquire an Elanscan interface, I have emailed Geoff to see if he has any available.
Any suggestions very welcome.
Thanks,
Ian.
