Enright wrote::goodposting:
Now where was that "this thread needs more pics" smiley?!?
Rusty Wishbone wrote:If anyone else in the UK wants a set of leads and split the postage cost, let me know. I need to know which colour leads you want and whether you want 7mm or 8mm. 7mm are $21.99, and 8mm are $26.99. Postage from the US is £25.15. Even if we get charged duty, this is much cheaper than the almost £100 I have seen elsewhere.
Cutoff for this is Sunday evening at 9pm when I shall place the order.
Fitted my Kingsborne 8mm leads and NGK Iridium spark plugs today!
Nice and easy to fit
Jon wrote:
Any chance you might do a quick write-up - I've got my lovely red leads here and I'm pretty familiar with my socket set - but I've tended to leave my engine area to a mechanic in the past, so any pointers would be appreciated.
Ian Till wrote:Nice car and good to see someone else in the Garden of England with one - I hope to buy one shortly. Do you go out to meets with it?
Ian Till wrote:The oil you describe in the spark plug bores is almost certainly coming from the rocker cover gasket - really common on some engines and depending on why it is leaking, really easy to fix. If it is a plastic rocker cover, you might find it is simply over-tightened and has distorted a bit, deforming the gasket. A new gasket might fix it, but I'd be considering replacing the gasket AND using a very thin bead of the Hylomar type instant gasket sealant as well, then refitting the cover according to the workshop torque (and tightening sequence) settings.
Jon wrote:Wonderful - thanks for the write-up. Think that has given me a pretty good idea of what is required (certainly would have been lost without it)....when I get a few hours to spare I'll give it a go!
