by Brmelan » Sat 13.09.2014, 16:57
Advice required please.
I am looking at purchasing an S2 elan with new MOT.
It needed plate welding on the chassis .
I have an old baby elan and welding those chassis was a "no no".
Should I
I understood S2's were rustproofed in a superior manner ??
Any comments gratefully received .
Thanks in advance .
Brmelan
by epipete » Sat 13.09.2014, 17:37
As a general rule of thumb welding the chassis is still a no no however much depends on how well it was done and the proximity of the weld to critical components.
You'll also need to know why it required welding in the first place ie rust or accident. If rust then what confidence can you have that unseeable parts are sound and if accident then what confidence in the repair, alignment etc.
Everything may be fine but you need to probe for some detailed background.
I'm not sure if S2's were better treated than SE's certainly the Wishbones were made of aluminium so that was an improvement but what else I know not
Good luck
by muley » Sat 13.09.2014, 18:00
Minor correction : S2 wishbones are galvanised steel.
Seems S2 chassis are more prone to corrosion than earlier NA/SE.
See also
http://www.motuk.co.uk/mot_appendix_c.htm..depends where the repair is and how close to suspension mounting points.
by Rambo » Sun 14.09.2014, 11:26
muley wrote:Minor correction : S2 wishbones are galvanised steel.
Seems S2 chassis are more prone to corrosion than earlier NA/SE Jim
That's correct - rear wishies were galvanised steel and not aluminium
Re S2 chassis being more prone to corrosion than N/A and SE's................I remember someone telling me recently (was it you at Silverstone Jim ?) that when Bugatti had Lotus they found a load of these chassis outside rotting away and incorporated them into the limited edition run of 800
At least, that's what I seem to remember but I do also remember that a few beers were involved so I might have got a few things mixed up in the old grey matter
- Don't push me
by Rambo » Mon 15.09.2014, 10:16
My local guy in the village has just done some welding in my car(new front jacking points/strengthened outriggers) without any particular problems but then again he has cut his teeth on the old Scimitar's
- Don't push me
by tb10 » Mon 15.09.2014, 17:32
Brmelan wrote:Advice required please.
Should I
Thanks in advance .
Its not a Purple one by any chance?
regards
tb10
by Rambo » Mon 15.09.2014, 18:09
just a thought, but how did this S2 get through its recent MOT if the chassis needs plate welding ?
- Don't push me
Return to Chassis & Steering
