Ted, this is what we did with the Protech.
1. Get the springs in the proper place.
2. Cut a piece of wood for the front measure and the rear measure.
3. Start lifting the collars until the wood clears the frame members.
Count the rings under the collars should match both sides for balance.
4. At this point we used scales and fine tuned the 4 corners by weight.
You could do it by measure and get close. Measure only at a metal surface.
No tub or body panel.
5. 1/2 tank of gas and driver seated for best suspension performance when
adjusting the collars.
It is much more complicated than this but should get you going.
Steve
