Hope I am not 'hijacking' this topic, but I think my question below is relevant to having new tops fitted, and a good answer would definitely help me, and quite possible some other members as well
Many many years ago, I did my apprenticeship in a Auto shop in Zambia, which included a few months working in the glass and upholstery division. Part of our business was also in restoring and re-upholstering old cars, and as Zambia was so far away from the OEM (in fact any) suppliers, we had to 'fettle' quite a bit.
@Daveiow: I have read in previous topics that when Car Hood replaced your hood, they managed to do that without damaging the header seal (as you say above, they replace the hood, but used the original seals).
Now, the material for the top is fitted to the frame before the header rail carrier is attached, so the only way to fit a new top is to get the header rail off. In order to do that, one has to get at 6 or 7 nuts... problem is, these nuts lie under the header seal.
I can only think of two ways this could have been done
1) Remove the header seal: Unless one is lucky, this option is quite extreme as the seals were often fitted with a bead of Silastik/RTV732 which tends to bond to them, and therefore generally results in damage to the seal. Maybe Car Hoods has some chemical which loosens up the seal?
2) Use a sharp hole punch to punch a hole through the seal above the nut large enough to allow a socket to go through, This would enable removing the nuts, and therefore the header rail carrier complete with seal, so no damage to the seal. After reattachment, a plug could then be used to fill up the hole. Even without the plugs, it shouldn't affect the sealing as the area of the seals where the holes would be fits flat against the top of the windscreen, and is compressed. Of course, opening the holes MAY be a problem as it would be opening the skin of the seal, enabling it to work more as a sponge as usual.
If it was the latter option that was used, there would probably be evidence of it... 7 small holes, or 'plugs' seen when the header seal is open.
I currently have my seal off (see topic below this), and as soon as I have worked out how, will be putting it back on..... trouble is, my soft top is tatty, and I am thinking of driving to the UK next year, and having a new one fitted.... but obviously don't want to have any risk of having to replace the seal then (waste of scarce Lotus resources and money)
So, if it is possible to use option 2, then I would like to punch the holes before replacing it this time... would be much cleaner and easier than doing it next time, and also, it is easier to work fitting the header rail into the carrier when it is off the car.
@Daveiow: Could you check your car and advise if there is any sign option 2 was used
@Everyone else: Do you think this would work, or am I just mad
