I replaced mine with these recently....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 1468510082
Jon wrote:Looks like you need some shiny new values![]()
Megwenda wrote:sorry to hear it failed
re the brakes, are they standard calipers?
Are the sliders siezed?
dapinky wrote:Have a read of this thread - it isn't really a great way to *fix* a maintenance issue, but if you've fully bled the system (by taking the callipers off the hubs and rotating them 90 degrees so the piston is uppermost whilst tapping with a small hammer to dislodge any bubbles) - it WILL work to get you through an MOT - you can have as much or as little pressure to the rear wheels as you want/need![]()
*Usual disclaimer* - anything you do to change the system without fully understanding the mechanics/physics of the change is at your own risk
they have a web site and list lotus on it might be worth a phone call ?
Rusty Wishbone wrote:Maidstone Sports Cars might be worth a call.
dapinky wrote:Sounds steep to me!
The Service Times list states 4.5 hours to replace a PAS rack.
The Workshop Manual procedure looks fairly straightforward, the worst bit is partial dismantling of suspension to give it room to come out (Prongeron and loosen one raft).
Again, the procedure for replacing all the seals is comprehensively explained, and whilst it looks 'specific' in what order you need to do things, it doesn't look difficult.
(basically, I'd do it myself - but if it is beyond what you're happy with, then try another garage, or at least get them to explain where their timings come from).
The high pressure pipes can be re-made easily (just like brake pipes) and I'd swap them to make life easier with the removal - it's easier to cut the copper pipe and do the fittings on the bench.
Maybe a compromise - take the rack out and get someone else to re-build it?
TrevorB wrote:Hope all goes well Jon, but I would be interested on MSC's quote as they are who I use for my repairs and MOT.
So if you can still give them a call to see what they say I would be interested.
Trevor
