B post trim
B post trim
Postby Ade » Thu 12.02.2015, 21:01
Hi all,
I am now repairing my outriggers but I broke my drivers side B post trim removing it, I didn,t realize there was an hidden screw under the seal at the top of the trim, which is worth remembering if anyone as to remove theirs.
The outcome is I need a new trim panel so if anyone as a good trim panel to sell I would be most grateful.
Many thanks
Ade.
Ade
Re: B post trim
Postby epipete » Fri 13.02.2015, 00:48
Ade, I know I have a spare but can't remember which side, I'll look in the garage tomorrow and get back to you.
Pete
Re: B post trim
Postby Ade » Fri 13.02.2015, 18:20
Hi Pete,
thanks for that much appreciated, lets hope its the correct side.
Ade
Ade
Re: B post trim
Postby epipete » Sat 14.02.2015, 17:40
Ade, I feel bad now for mentioning and raising hope but unfortunately the side I have is the Passenger Side, sorry :banghead:
I hope your search is successful elsewhere.
Pete
Re: B post trim
Postby Ade » Sat 14.02.2015, 18:26
Hi Pete,
thats ok, thanks for trying.
Ade
Ade
Re: B post trim
Postby epipete » Sat 14.02.2015, 19:04
I guess that there is always Douglas Valley, I wonder what they'd charge? On the other hand I suppose that is what brakers yards are useful for.
Re: B post trim
Postby Ultimatt » Sat 14.02.2015, 20:24
Hi Pete
Not wishing to hijack Ade's post, but how much would you want for your B-Post trim?
My passenger side got broken when the mechanic removed it to free up the seatbelt mech for its MOT last year.
Matt
M100 Elan SE:
Metallic Gold Fleck Red.
Carbon intake pipes.
Bailey recirculating BOV.
Samco hose kit.
Pro-tech shocks.
S2 wheels.
16" Wilwood Brake upgrade.
S/S Exhaust system.
Everest Chip !
Ultimatt
Re: B post trim
Postby epipete » Sun 15.02.2015, 00:52
Matt,
I have no idea, send me a pm with a suggestion, I'm not avaricious!
Pete
Re: B post trim
Postby Ade » Sun 15.02.2015, 19:57
Hi Pete.
I thought about Douglas Valley, i,ll give them a ring to-morrow.
Ade
Ade
Re: B post trim
Postby Brit-Car-Nut » Sun 15.02.2015, 22:28
Remember, there are TWO different versions of B Post trim:
The early type used a cap that has a plastic slider that acts as a hinge and two springs to close it.
The later design used a sprung piano hinge.
Make sure you get the correct version for your car.
Re: B post trim
Postby Fredjohn » Mon 16.02.2015, 00:07
Brit-Car-Nut wrote:Remember, there are TWO different versions of B Post trim:
I guess it depends on whether Ade wants the b post trim cap (2 types as correctly defined by BCN), or the vertical trim panel.......
Re: B post trim
Postby Brit-Car-Nut » Mon 16.02.2015, 00:17
The vertical cover ("B" Post Trim Panel in the parts book and Seat belt cover in the workshop manual) are different just like the caps, so you need to get the correct cover so it matches the cap you have.
Just click on the picture to be able to read it.
Re: B post trim
Postby Ultimatt » Mon 16.02.2015, 16:11
In light of the feedback and different model specs, could you possible do a photo or two Pete so I can compare?
I think it will be the top end around where the belt comes through that will likely differ.
Matt
M100 Elan SE:
Samco hose kit.
Pro-tech shocks.
S2 wheels.
S/S Exhaust system.
Everest Chip !
Ultimatt
Re: B post trim
Postby Enright » Mon 16.02.2015, 17:07
Look in this thread for pictures of the different types:
viewtopic.php?f=30&t=21650
Re: B post trim
Postby epipete » Mon 16.02.2015, 17:52
I shall try to send/post up some pics again later, I've been trying but the system keeps rejecting them due to size (my old phone used to allow me choose the definition prior to taking this cutting edge later phone wont!!!!) :evil:
I believe mine is the later version.
Pete
Re: B post trim
Postby Brit-Car-Nut » Mon 16.02.2015, 18:09
Here are pictures of each type looking from the inside: Click on each picture for a larger view.
This has the all plastic sliding pivot
This uses the spring loaded piano hinge.
Re: B post trim
Postby Ultimatt » Mon 16.02.2015, 18:37
Hi Pete,
If its an iPhone, you can email them to yourself and it will ask you what file size you wish to send small, medium, large or original.
Matt
M100 Elan SE:
Samco hose kit.
Pro-tech shocks.
S2 wheels.
S/S Exhaust system.
Everest Chip !
Ultimatt
Re: B post trim
Postby epipete » Mon 16.02.2015, 19:51
It is the lower of the pics above.
Using a Windows phone but will re photo using the Ipad
Pete
Re: B post trim
Postby Ade » Wed 18.02.2015, 16:37
Hi all,
I have now located a B post trim panel and it is being sent from Douglas valley spares, they were very helpful, but very expensive. It cost £50+Vat+shipping.
I am glad that it was mentioned that there are two types, if not I would have bought the wrong one, they have both types and the one I need is the later one.
Thanks all for your in-put.
Ade
Ade
Re: B post trim
Postby Jeemy » Wed 18.02.2015, 17:38
OOf. I've got 4 sets, two per side that I am going to put up for sale. At present I am guesstimating prices, I have a guy going through them all comparing DVB/ebay, DeRoure and SJs and then taking 20% off the average, or you know, working it out to be fair.
I have to say I would have guessed £25 on these, and then discounted LEC 20%. That said, its only pounds and you've got the bit so its no big worry in the great scheme of things.
T: 0800 084 3084
M: 07391 295 146
Jeemy
Return to Interior
