I'm the proud owner of a bright yellow S2 Turbo. I've been a bit worried about the temperature of the car, in that the temperature gauge doesn't move and then suddenly jumps up high and the fans come on. Having read the forum, it seems that this is pretty normal? In any case, I was shuffling my cars about a while back and when the fans came on I noticed that a bit of steam was rising from the front of the car - not much, but enough to notice.
I hadn't driven anywhere, so there was not any water sprayed onto exposed hot parts of the engine, so I assume I've got a small leak somewhere.
Looking through the grille, I see this on the radiator:
Is my radiator on the way out?
Thanks!
