dapinky wrote:The other one which causes problems (well, it did to me - and Pete as well) are the M6 thread which holds the bottom of the headlamp pivot bracket - it is a bighead bolt and mine had rusted and just turned when I wanted to undo it - once the clamshell is out it's easy to replace - I used stainless ones.
epipete wrote:And just to add to that, although I've never removed one myself, iirc there may be some spacers (is this right Dave?) the positions of which you should note for re installation.
tb10 wrote:Hi Joao,
Sometimes the very fine connectors on the lightbulbs themselves don't make contact with the loom connections or the connections themselves are dirty. Therefore clean the connections first and use your multimeter to check the voltage and then, if there's power, its got to be the bulbs. I say this as I had a similar issue.
regards
Tuga2112 wrote:job done, now im not sure if both calipers are stuck or if both are good.
i took the car for a run, never gone faster than 40, and when stoped felt all discs. front ones where all too hot to keep the fingers there for more than a second, and the rear ones were luke warm.
i used copper grease on the sliders on reassembly as both my friend mechanic and the auto parts store told me to, (not sure if that is a silicone grease or some other equivalent alternative)
tomorow gonna take the car to work, see how it handles.
when i get back. assuming i dont spend hours working on something ill post the leftover pics from the painting, and start planning on the next upgrade.
lotusflasherman wrote:Tuga2112 wrote:job done, now im not sure if both calipers are stuck or if both are good.
You may be able to find your problem by pad temperature - if the piston is sticking the inside pad will be hotter, if the sliding part of the caliper is sticking on the pins the outside pad will be hotter. With both pads removed you should be able to move the travelling part of the caliper in and out quite easily on the pins. Also check the piston moves in fairly easily. If it moves in OK it will have no problem coming out with fluid pressure behind it. If both these are OK your pads shouldn't rub the discs and get hot - though they do rely on a bit of disc run-out to knock the pads away. Single piston calipers have a habit of seizing on the sliding pins as they rust up a bit so unscrew them and get them back to bright metal with a bit of fine emery cloth and then some copperslip grease before reinstalling.
