Regulator, again !
Regulator, again !
Postby Neil D. » Tue 19.05.2015, 20:25
Been away for some time, but a damaged window regulator needed attention, and the best source of information remains here.
The problem is somewhat different from the usual. The "transfer ring" made of rubber that sits between the gear wheel and the bottom of the casing has been chewed up. This caused the cover plate to bend, and the cable to get mangled.....
being in France, Peugeot parts are easy to source. But has anybody contacted the regulator manufacturer ?
http://www.lamesgroup.com/eng/prod_gear_motor.htm
Also on the S2 ( at least lhd ) the regulator is also held in place by a plastic part that is riveted behind the regulator ( 3 rivets )
Cable appears to be 1.92 mm, 2.00 m should fit ?
Any info and help appreciated
Neil
S2 # 541
Neil D.
Re: Regulator, again !
Postby Neil D. » Thu 21.05.2015, 13:28
Reply from Lames SPA
"I regret to inform you that the particular requested is out of production
for many years and we haven't in our warehouse.
You might ask the following company that produce spare parts:"
http://www.miraglio.it/
catalogue here...
http://www.miraglio.it/pdf/MIRAGLIO_ALZACRISTALLI.pdf
PEUGEOT 405 / 406 remains the closest
Neil
S2 # 541
Neil D.
Return to Doors and Windows
