Misfiring and some white smoke
Re: Misfiring and some white smoke
Postby Brit-Car-Nut » Sun 07.06.2015, 03:40
coopersg wrote:How about these NGK coil packs on Ebay:
http://www.ebay.co.uk/itm/New-NGK-Ignit ... 1e9e6c1075
I see no reference to NGK in the Wiki or the forum which is strange.
Stewart
You could consider the DR39 coils from Rock Auto. They are absolutely correct and very inexpensive since every GM car for over a decade used them.
Postby coopersg » Sun 07.06.2015, 19:50
Thanks! Ordered.
coopersg
Postby Pascal » Mon 08.06.2015, 23:01
Thank you Geoffrey and I apologize to all,
I don't know how the two topics did mismatch as they had two different names at the beginning, likely I did wrong.
Pascal
2020 May 21- Ieper Lotus Day ! I'm not ready ! I need a hair cut ! Pascal - North of France - 1991 SE Turbo Calypso (faded to pink) Red and an additional Elise somewhere in the garage
Pascal
Postby coopersg » Tue 07.07.2015, 12:17
I replaced the ignition coils yesterday and all is well. I can see on one of the removed coils that one of the HV studs has a lot of corrosion. That may not have been the issue, but I could have probably fixed that if I'd checked earlier. The new coils seem to be performing as intended.
Thanks for all the help and suggestions. Lets hope that any other work I have to do in future does not involve the same level of contortion!
Stewart
coopersg
Postby John_W » Tue 07.07.2015, 20:18
Stewart,
Glad you got it fixed.
