Ian T wrote:Amusingly described as a 2-door, with manual transmission and a fuel type of 'other'.
At least the last element of those three descriptive items is correct...
Of course it would be plagiarism, but wouldn't it be interesting to buy that buck and make moulds from it and transform a damaged Elan into it?
Ian T wrote:LOL. You wouldn't want the one-off then?
I realise that the amount of work involved is monstrous, took Lotus millions of Pounds to do, etc etc etc.
Meant to say, I saw a brand new M100 boat the other day at Bromley Pageant - unused from the factory and in primer. Even I would rather reshell a duff one than take on the task of trying to create a different car.
Rambo wrote:It's done 10 miles
lotusflasherman wrote:Ian T wrote:LOL. You wouldn't want the one-off then?
Nope. Don't like the look of it and not distinctive enough... bit like a Renault Alpine GTA/610 but without the muscles. Looks more like a 2+2 and fixed head too ... and one of the plastic wheels trims is broken !!!!!
Who enters a design competition for a World Championship Winning Car Constructor and puts plastic wheel trims on it?![]()
I attended a lecture at Cambridge Uni' given by Peter Wright in the mid 80's. It was supposed to be about the application of active suspension to road vehicles (ambulances in particular) but he also spoke about the development of the ground effect Lotus 78 & 79, which had then been banned so he wasn't giving any secrets away. He explained how they used hot and cold air flows & also went into how this could be used on road cars at the design stage. A flat bottom and curved upper surface (most cars) acts like a wing that will give low pressure over the car and create lift at high speed so the ideal profile is raised in the middle between the axles but looks like a banana. A more pleasing design stops the air going under at the front, has wasted sides with concave curves that create low pressure zones and extract air that is under the car to create low pressure under and eliminate lift.
Peter Stevens' design for the M100 incorporated those ideas (so keep the rubber bib in good order and don't put side exhausts on an Elan or NACA ducts in the bonnet) and the design of TVR's shortly after seemed to pay close attention to airflow under the car too. Ital seem to have a rear spoiler and undertray to counter lift but not really an elegant design solution.
If I really wanted a one-off that was never made I think the M300 is a bit more exciting...peterstevensdesign.co.uk/design/lotus-m300-
or maybe this..peterstevensdesign.co.uk/design/elan-coupe ... interesting that radiator exhausts out of the bonnet and no pop-up headlights
rip wrote:Rambo wrote:It's done 10 miles
Dico won't want it then?
Nickydee wrote:Just had a look at Peter Stevens website and compared the Elan coupe and the MG TF coupe. In the past there was talk that the MGTF hardop that Peter designed was in fact a rehash of the Elan one and I must admit I was sceptical. However comparing the Elan coupe and MGTF coupe http://peterstevensdesign.co.uk/design/mg-tf-coupe- roof treatments they are almost identical.
Return to General Lotus/Isuzu Discussion
