Sorry, missed your message!
No, CTS seems to be plausible all the way through the range. Geoff has also looked at the Elanscan dumps earlier in this thread and concluded that it looked OK.
Anyway, another day, another fiddle and a little more news.
Easy stuff first - cosmetics. I have been embarrassed since I bought the car about the state of the wheels. Maybe they were distinctive with their green primer with a hint of silver overspray, but I desperately wanted them to look like everyone else's... So I have been taking them off one by one and painting them. The first one has faulty poder coat and so the results aren't what I was wanting, but the second one has come out nicely enough and once the paint has completely gassed off and hardened, I'll polish it up. A couple of photos below show that the car shouldn't be as scruffy at this years Lotus Festival.
- Masking tape about to come off...
- Masking removed
Of course I have been trying to work out what is causing my poor start condition and slowly rule out some options but as often as not start asking more questions. See what you guys and girls think.
Firstly, I investigated the Crank Angle sensor and have created a separate thread about that asking whether it looks to be assembled correctly. While apart, I cleaned it all up a little and checked the alignment of the sensors inside. Only on having it to bits did I realise how it works - I had assumed that there was a crank sensor on the bottom half of the engine like every other fuel injected car I've worked on. Nope, this seems to do it all from the exhaust cam. the reluctor wheel provides pulses to the ECU telling it (twice per revolution of the cam) when cyl no1 gets to TDC and the hall effect sensor detects a steel flag passing through it that tells it which way up the cam is (i.e. whether to fire cyl 1 or 4). I can't convince myself that the CAS is assembled correctly, if you have photos, or time to look, have a look and tell me if yours is the same under the plastic cover.
With the crank rotated to bring Cyl no1 to TDC, the CAS reluctor ring is set like so...
- CAS reluctor with Cyl1 at TDC
I can't quite satisfy myself that this is correct, but can I find any information online to know how to check? LOL.
I also had another go with the Gunson Gastester (the replacement after the first one melted internally). If Mr Gunson is to be believed, the CO is set at about 3% after some adjustment of the CO pot in service mode. I can't say for sure that the adjustment is right as I don't quite believe Mr Gunson and will take it to a friendly local garage to put on their MOT tester and see what the score is.
Obviously, it had to sit there idling for a while in service mode so having previously swapped the plugs round and driven the car, they were initially equally coloured and fouled. Not fouled so you'd think them to be unhealthy, just not shiny, brand new and white. as soon as I cut the engine, I pulled the plugs out to look at them and this time the result is different. Anyone care to comment? Cyl 1 and 2 are black, but the plug gap area is nice and brown, with a tiny bit of brown extending one side of the earth electrode. Plugs 3 and 4 both have white spots on the porcelain on one side only, the earth electrode has warmed up much more and cleared any sooty deposits, photo below...
- Plugs laid out in order - 1 on left, 4 on right
Previously that lean looking plug effect was only on cylinder no3, no matter which plug was in there. What have I changed that has extended that effect to no4?
