Andy_J wrote:Looks like and aftermarket 'upgrade' down pipe.
Steve A wrote:Andy_J wrote:Looks like and aftermarket 'upgrade' down pipe.
The welding looks very DIYI'm interested to see the turbo end
That's not welding, it's 'sticking it together with slag'. It's either DIY or done by the apprentice without supervision.
Enright wrote:I have one or two standard originals that I wouldn't mind parting with.
Do you want me to bring the best along on Sunday and you can make me an offer if interested?
Steve A wrote:The wire mess section is used because it is flexible (which is a good thing), you can buy them separately just google flexi exhaust joint.
I have incorporated one into my system (look through my posts and you will see).
Rob P wrote:Steve A wrote:The wire mess section is used because it is flexible (which is a good thing), you can buy them separately just google flexi exhaust joint.
Cheers Steve
I was wondering if it was a de-cat piece but flexi exhaust pipe, that sounds like a sensible idea so will see if I can ensure one is incorporated in the replacement piece
Rob P
GeoffSmith wrote:AKA sump guard!
Rob, I'm pretty sure Paul put a Peco on and it looks like a Peco=Cybox front section who are just down the road from you...
dapinky wrote:Rob,
I have to say that you're not the first person who thinks your pipe has cr@p welding.....
I told Paul it wasn't great when he first got it!
Unfortunately, I think the issue is that the pipe is stainless, but the MIG wire was mild steel - which will stick, but the 'filler' will corrode deminishing the whole piece.
From the best of my recollection, the welding was reasonably solid (anyone who has seen my own welding ability will tell you that I can always get 'solid' but not always 'pretty') and was 'as supplied' for the turbo upgrade.
It may well be worthwhile to take it to someone who has the correct MIG wire and shielding gas and ask them to cut/rejoin the offending piece??
dapinky wrote:Rob,
It was part of the turbo upgrade kit supplied by LGM - so I assume it was made up in San Fransisco (or somewhere over that side of the pond). Certainly not 'local'.
