epipete wrote:So this is the wrong way round? Furthermore I have a small pipe going to the Plenum IIRC.
Pete, I can't see what make of valve you have, but I have to assume that they are all pretty much the same design, so yes, according to Forge (for the information as disclosed above) it is wrong...... (now comes the long-winded explanation - because i know you've got the time to read it).....
.... but it will still work (mainly) as intended, but will open sooner than it should due to the fact that the boosted air is pushing against the piston/spring.
Let me try to explain it in simple terms (because it's how I understand things!).
Now, the numbers I am using are just random ones from the top of my head - all units and values are just for example.
Lets say that the green spring has a value of 5 units, yellow is 7 units, and blue is 9 units - when the valve is standing in atmospheric air, any spring will hold it in the closed position - but some more firmly than others....
the small pipe to the plennum you mention is the vacuum operation pipe - when you open the throttle air is sucked in to the engine, and a partial vacuum is formed in the plennum due to the lower pressure ('coz the air is now in the cylinders!). This lower pressure drops the pressure in the DV by the same amount (due to the hose between them) - but only on one side of the piston seal.
Lets assume that the vacuum pressent in atmosperic conditions are 1 unit - when you have light throttle, that increases to 2, 3 or 4 units - but as it is less than even the lowest spring value, the piston remains closed.
When you floor the throttle and the pressure drops in the manifold, the vacuum may then go up to 6,7 or 8 units. If you have the blue spring fitted it will remain closed, as the spring still exceeds the vacuum, but if you have the yellow or green springs, the valve will open - lets say 10% open for the yellow spring, and 50% open for the green one.... okay so far? (This is just in NA mode - the turbo isn't doing anything at this point).
Hence you need the correct spring rate for the car/engine - nowt to do with turbo boost.
Okay, so if the spring is too weak, and the valve partially opens at full throttle, what does that mean in practical terms? - no great effect on the operation of the engine, but the open valve will allow unfiltered air from the engine bay to get sucked in to the manifold to fill the vacuum void (via the DV) - in the case of a recirculating valve, it will pull air from the unfiltered side of the airbox - again, not the end of the world, but not ideal.
Thus a DV can be fitted to ANY car (not just a charged one) - and is the premise that the kiddies with their Vauxhall Saxos use to get the whooshy noise in McDonalds car park - they just fit a weak spring and let it make 'fast noises' when they push/lift off the throttle.
Anyway, enough of the 'Modified Vehicle Brigade' - back to your physics lesson.....
Once you have selected the right spring rate for the maximum vacuum you will develop (as stated, I use a Green spring) we need to consider what the turbo pressure brings to the table..... sod it, whilst we're still on spring selection, lets leave the theory and do something practical.... "How do you decide which spring to use to start with - other than total Trial & Error?".....
Firstly, see what other people have used in the same application (Green!), then see how it works in your car.....
....Fit the vacuum pipe to the valve and hold it in your hand (this assumes that you have no valve fitted already, and have yet to cut the intake pipe - but if you already have the pipe adapter fitted you'll need to fit the DV to it (the right way round!) so that the flat end of the piston is visible & accessible. Use a small length of wood (a flat end of a pencil is ideal), push against the piston and feel the spring tension - it should be quite firmly held closed.
Now start the engine and let it idle - push the pencil again and you should see that it takes less effort to open the piston a bit (spring pressure remains at 5 units, but vacuum has changed from 1 unit to 2 units, so there is only 3 units to overcome with the pencil) - gently rev the engine to a steady 3K revs (or whatever) and see how much the pencil now needs - it should get a tad easier, but not much.
Using your third hand (or an assitant in the car?) rev the engine a few times whilst holding the pencil against the piston - you will actually feel the difference in pressure required to move the piston as this happens.... Maximum vacuum is achieved at maximum accelleration rate (of the pistons in the engine, not necessarily the car!) - not the maximum speed of those pistons - although max accelleration occurrs just before maximum speed (well, it doesn't really, but without going into the dynamics of the whole thing, it can be taken as pretty much that, for our purposes).
Basically, get the assistant to floor the throttle whilst you hold the pencil - if the piston in the valve moves a lot, you need a stronger spring - if you still can't push it open with reasonable finger pressure, you need a weaker spring - if it 'just about' starts to open on its own, perfect - (or with minimal 'push' from you).
Right, enough playing - back to the theory....
With the right spring fitted, the valve will remain somewhere between firmly shut (engine off), and just-about shut (*maximum* vacuum) - - so it's like spending a hundred quid on nowt at all
... but then the magic happens - we add some extra pressure to the inlet charge from the turbo.
We all appreciate that when the turbo spools up, the physical volume of air between the turbo and the throttle body remains the same(ish), but the volume of air entering the system is larger, therefore simple Physics dictates that the pressure (and temperature, but that is irrelevant to todays lesson) of that air must increase in that fixed volume (if it didn't there would be no point in having a turbo!)......
.... and it is this increased pressure of air being forced into the engine which allows more fuel to be burned and gives us more power.
Depending on the levels of boost produced (0.65 Bar for a 'standard' SE/S2, and up to 0.92 Bar for a 'chipped' car), the ECU will allow the injectors to supply the right quantity of fuel to burn efficiently, and thus produce maximum power.
But when you lift off the throttle, the pressure in the enclosed part of the system remains higher than atmospheric levels, and it has to go somewhere - hopefully into the engine, but not instantly, so it will start to push back against the turbo impellor (fluttering sound can be heard as the pressure causes the blade to slow down and back-pressure escapes the wrong way) - or a pipe /clip bursts.
If this is only for a short time (gear change), it soon goes the right way again, but there is a momentary 'lag' until it is flowing fully - if the turbo isn't used again straight away (lift-off after an overtake??), it settles down to atmospheric pressure and away we (less vigourously) go.
Now, the DV works at this point - the vacuum vs spring equals out, and the valve opens (theoretically, it will open fully once the vacuum exceeds the spring values, but in reality it is probably a 'partial' opening).
With the valve the 'right' way round, the levels of boost will have no effect on it's operation, but when it opens, the excess pressure releases to the engine bay (or back into the air filter box in a recirculating system), This means that the pressure just before the throttle body stays at 0.65 (or 0.92) Bar, and is instantly available again when you hit the throttle - the turbo blades are still rotating freely and there is no 'catch-up' required, no fluttering sound from the fan blades, and less stress on the entire turbocharger unit - which has to be a good thing for the longevity of the parts.
If the valve is the 'wrong' way round, the pressure at the DV will still be 0.65 Bar, but it is also pushing against the piston/spring....
....this is where boost pressures DO matter to the spring selection.
If the spring is too weak, the spring value (5 units) remains the same, the vacuum (4 units?) tries to open it, but the boost pressure *may* add a couple of units of 'push' to the piston from the other side, and it now overcomes the strength of the spring, and opens the valve. This allows precious boost to escape without getting to the engine. If it only ocurrs at lift-off conditions, no problems at all - that's what the valve is for
BUT - if the boost/vacuum overcomes the spring BEFORE the saturation point (lets say the turbo adds 1 unit of 'push' for every 0.3 Bar of pressure), you will never maintain full boost, no matter how much pressure the turbo is developing.
In this example, you will have 5 units of spring holding it shut, 4 units of vacuum trying to open it, and with the turbo doing nowt, all is well. Once the turbo develops 0.3 Bar (1 unit of 'push'), the valve will reach equilibrium. If the Turbo develops 0.65 bar of boost, the valve will open as it now has a '1 unit' negative against the spring, and so all excess pressure now developed will just escape to atmosphere, and not get into the engine... hence anything over that is 'wasted' boost.
So in that case, you will need to fit a stronger spring to maintain maximum boost (a yellow spring with a value of 7 units would be okay in this case, as the 4 units of vacuum, and 2 units of boost would still keep the valve shut...... but if you have chipped the car to 0.92, then we will have 3 units of boost added to the 4 units of vacuum, and it will be marginal, so you may need the blue spring).
Are you still awake at the back?
Bottom line - if the valve is the right way round, once you have the right spring fitted, it doesn't matter what you do to the boost pressure, it will work exactly the same.
If it is fitted the wrong way round, you may need to play with spring rates to get it right, but then it will continue to work the same unless you 'up' the boost.....
..... but every time you run the engine on boost, the valve will be pushing against the spring unecessarily, and will (eventually) start to wear the spring - so for maximum life from the unit, fit it right and leave it alone
Class dismissed
