- they are the ones i used and they fit both inner and outer joints.| Home | WikiLEC | Repairs | Upgrades | Gallery | Buy & Sell | Mountain Chips | Meets & Events | Contact |
- they are the ones i used and they fit both inner and outer joints.Tuga2112 wrote:no one was impressed with the alloy paint work
epipete wrote:Sorry Joao, didn't realise you were fishing for complements![]()
... specially after spending 2 weeks on a job that should have taken 1 or maybe 2 days. sanding down the wheels was a pain... until i gave up and bought a sand blaster... and finally learned how to use it. mine was always clogged because i assembled it incorrectly and assumed sand wouldn't need to be filtered.dapinky wrote:Whatever you're using though, just make sure it doesn't get into bits that you don't want it in - like the engine!
epipete wrote:dapinky wrote:Whatever you're using though, just make sure it doesn't get into bits that you don't want it in - like the engine!
Or your eyes
dapinky wrote:You're quite correct, of course! - I was sort-of assuming the H&S bits were taken as read!
cliff wrote:By the way Mods, given the amount of work done, think it is is time this thread was moved to Major Projects?
cliff wrote:Hi Joao,
not sure why you can't get the hub off, mine slid off with no effort.
2 points though, wd40 is perfumed mineral oil and must win the award for the best marketed, useless product on the planet and that includes Cameron, Obama and the Kardashians. Get a good penetrating fluid.
Secondly, a 9.99 puller can never be classed as heavy duty, they are usually made out of coloured cheese. I think you might need something a bit more up to the job. Not sure which side you are having problems with but you might be as well to remove the whole drive shaft and do it on the bench or take it to a friendly garage. One side will pull out easily, for the other, you have to remove the 2 bolts holding the jack shaft.
Good luck.
