HJ2 wrote:Welcome aboard.
You could also check your exhaust line including manifold for cracks.
xamol wrote:Would I check for leaks/cracks by just eyeballing and looking for staining from exhaust fumes or is there a more scientific way to go about it?
lotusflasherman wrote:Best way to investigate this is bing a plug up the exhaust pipe with engine ticking over and the leak should start to hiss at you. If there is no leak the engine will stall....
completely!HJ2 wrote:Whilst checking the spark plugs if they were seated properly (they were) I noticed a small oil leak from the valve cover. The bolts are prone to undo them selves, even when torqued to spec.
Also i ordered a new seal for the fresh cabin air intake a couple of months ago. Time to change it, clean the engine and see if the problem is solved now
