Candles wrote:Fellow Elaners,
I recently pulled my Elan out of storage where it had resided for 4 years. I drained and flushed the cooling system and replaced the thermostat with one of these:
QH-Benelux QTH102K Coolant Thermostat
Now I have an issue; the car is really slow to warm up. It can take an age (~5 miles) for warm air to flow from the vents and normal operating temp is rarely reached on a steady drive - it is as if the thermostat is either too low a value or stuck open. It wasn't stuck open when I fitted it, so is 88degC too low?
Thanks, Candles.
Nickydee wrote:I had similar issue with mine with a couple of non OEM thermostats, both bought using part numbers on the Wilki. The issue appears that same dont have a jiggle pin in one of holes which obviously restricts the flow- Think there is thread from Britnut re this somewhere.
Replaced mine with a proper Lotus item - about £15 so twice the price of the non OEM but solved the problem. My exhaust pops less now so think before car was overfueling which is not ideal.
lotusflasherman wrote:Nickydee wrote:I had similar issue with mine with a couple of non OEM thermostats, both bought using part numbers on the Wilki. The issue appears that same dont have a jiggle pin in one of holes which obviously restricts the flow- Think there is thread from Britnut re this somewhere.
Fueling has nothing to do with the thermostat or the temperature at which it opens. Information for fueling is sent by the Coolant Temperature Sensor - which is hidden away down the back of the engine and not to be confused with the Temperature Gauge Sender which sticks out the top of the Thermostat Housing and only drives the gauge.
As far as I know Lotus have never made thermostats so I consider there is no such thing as 'a proper Lotus item'. As long as you buy the right design it will work. The one I've fitted was physically identical to the one that came out and works fine.
Nickydee wrote:
Wasn't suggesting that the thermostat was hand crafted in Norfolk by carrot munching artisansbut simply that the one sourced via a lotus dealer is the correct item.
I brought two using the wilki part nos which were incorrect. I don't doubt the correct item is available elsewhere and others have successfully sourced the right item outside lotus. However there are a few who have has the same experience as me.
I would agree its usually silly to pay extra for the correct part wrapped in a Lotus box but in this particular instance for the sake of a fiver it might be preferential to get the OEM part - as this will either solve the problem or leave no doubt that this not the cause.
Re overfueling then if the engine is running cold due to an incorrect thermostat then would be detected by CTS, which may lead to the engine running richer than it would if the coolant was at "normal" temperature.
Wouldn't airlock lead to overheating due lack of circulation rather than running cold.
