Rambo wrote:Most people use no strap as the original has perished away many moons ago. It does virtually nothing anyway and the tank sits perfectly in place without it. Unless you were restoring your Elan to concours condition, I wouldn't bother.
With regard to the tank, the replacements have been known to split easily and there have also been problems with the (yellow) pressure cap. Again, I wouldn't bother with replacing as the original has done well for the last 25 years or so and can be cleaned up well with a bit of patience.
Rambo wrote:Most people use no strap as the original has perished away many moons ago … and there have also been problems with the (yellow) pressure cap.
Rambo wrote:PS I'm fairly certain JohnW found something good for cleaning his header tank. Can't remember if it was Milton's sterilising fluid or a Steradent but a search might yield the right info.
GeoffSmith wrote:Rambo wrote:PS I'm fairly certain JohnW found something good for cleaning his header tank. Can't remember if it was Milton's sterilising fluid or a Steradent but a search might yield the right info.
JohnW..... more likely to be Steradent.
Rambo wrote:GeoffSmith wrote:Rambo wrote:PS I'm fairly certain JohnW found something good for cleaning his header tank. Can't remember if it was Milton's sterilising fluid or a Steradent but a search might yield the right info.
Mixed with some Viagra, cod liver oil, raw garlic and glucosamine
dapinky wrote:The 'issue' with the pressure caps was nowt to do with the colour - it was the fact that some sealed properly and some didnt......
..... if you get a £2 yellow one from China it doesn't seal as well as a £6 yellow one from Germany.
Perhaps they use cheaper yellow paint in China???????
GeoffSmith wrote:Strap? What strap? Maybe it was an S2 added lightness feature like the missing rubber boot on the boost sensor.
dapinky wrote:As I'm sure you (and everyone else) guessed, i was being flippant with the cap nationality - just trying to emphasize that cheap caps, whatever their colour, are likely to be 'not as good' as more expensive ones
Rambo wrote:dapinky wrote:As I'm sure you (and everyone else) guessed, i was being flippant with the cap nationality - just trying to emphasize that cheap caps, whatever their colour, are likely to be 'not as good' as more expensive ones
Header tank cap bigotry. They'll be getting a new Minister in Brussels before you can say Weston Super Mud
