by steble » Sun 07.02.2016, 22:25
Gave the elan a service yesterday, oil change (what an arse that filter is!!!)
New plugs, (last person that replaced them put the wrong ones in)
New leads
Finished off with a tarty new oil cap
YELLOW ELAN M100
SUZUKI IGNIS SPORT
steble
by Simon_P » Sun 07.02.2016, 23:52
steble wrote:Finished off with a tarty new oil cap
Well at least you can be sure it will provide the same performance gain as your proposed intake mods
by steble » Mon 08.02.2016, 11:13
ALL OF FA LOL
BUT I HAVEN'T PROPOSED ANY INTAKE ONES. I'M JUST GOING TO RUN A K&N FILTER IN STANDARD BOX. JUST DON'T LIKE THE WAY THE INTAKE PIPE RUNS
YELLOW ELAN M100
SUZUKI IGNIS SPORT
steble
by rip » Mon 08.02.2016, 11:46
steble wrote:Gave the elan a service yesterday, oil change (what an arse that filter is!!!)
Yep. I use K&N oil filters now because they have a 1" removal nut designed into their casing. Getting a spanner on there is not easy, but I can't get any 'normal' removal tool on there.
by steble » Mon 08.02.2016, 13:09
rip wrote:steble wrote:Gave the elan a service yesterday, oil change (what an arse that filter is!!!)
next time round I will be going for one of those too lol
I ended up going for the smash a screwdriver through it option lol
YELLOW ELAN M100
SUZUKI IGNIS SPORT
steble
by Fredjohn » Mon 08.02.2016, 13:46
Need to be very careful removing the air filter. I forgot (!!??!!) to disconnect the battery, the spanner shorted across the starter motor contacts, got too hot to touch and warmed the oil filter very nicely thank you!!!
Fortunately no damage was done, but two salutary lessons were learned: disconnect the battery and buy a K&N filter next time!
by Simon_P » Mon 08.02.2016, 17:28
Fredjohn wrote:Need to be very careful removing the air filter. I forgot (!!??!!) to disconnect the battery, the spanner shorted across the starter motor...
That's a very long spanner you have Fred!
Steble,
Lotus weren't happy with the intake routing either - Details in the Hughes book.
I suspect that they had the intake facing backwards for a reason though.
by Rambo » Tue 09.02.2016, 10:01
What plugs did you put in steble ? And what were the wrong ones you removed ?
- Don't push me
by Rambo » Tue 09.02.2016, 10:02
Any of these ??
http://wikilec.9600.org/index.php/Spark_plugsThe reason I ask is that the Wiki recommends 2 types and the gap differences are either 0.8 mm or 1.1 mm ??? Anyone know why the gap size should be so different ?
- Don't push me
by steble » Tue 09.02.2016, 14:21
Rambo wrote:What plugs did you put in steble ? And what were the wrong ones you removed ?
Any of these ??
Ah I didn't know there were alternatives, I put in the top ones on that list. which are listed on the PNM website (and damn near everywhere else lol)
The ones that were in there were the NGK 1.1mm gap ones
YELLOW ELAN M100
SUZUKI IGNIS SPORT
steble
by steble » Tue 09.02.2016, 14:22
Simon_P wrote:Fredjohn wrote:Need to be very careful removing the air filter. I forgot (!!??!!) to disconnect the battery, the spanner shorted across the starter motor...
Steble,
that's interesting I'd like to give that a read, will see if i can find it via google
YELLOW ELAN M100
SUZUKI IGNIS SPORT
steble
by tigerdog » Sun 13.03.2016, 00:46
Rambo wrote:The reason I ask is that the Wiki recommends 2 types and the gap differences are either 0.8 mm or 1.1 mm ??? Anyone know why the gap size should be so different ?
I used NGK Iridium, originally with 1.1mm gap. Wide gap caused misfires under hard throttle and boost in Smaug. Rather than chuck them, I went old school and regapped them to .8. All was fine after that.
Return to General
