Share your pictures!
by lotusgirlmarie » Mon 24.08.2015, 04:14
Were just out to dinner in it. Went to a new (to us anyway) spot out in the marina. Was yummy.
lotusgirlmarie
- Goddess
by tigerdog » Mon 24.08.2015, 17:43
One of these years, we all really need to get together...
by Ekapol » Tue 15.03.2016, 00:29
Got new rubber grommet installed
Thanks to LGM~!!
Ekapol
by tigerdog » Fri 25.03.2016, 19:07
Looks great, Ekkers! Just curious - where did you (or Marie) source the grommet? It's much closer to the factory original than the one I bought from SJ a few years back.
by John_W » Fri 25.03.2016, 23:14
Just cool.
- Heid-bummer
by Rmiddleton » Fri 28.10.2016, 16:55
where did you get the convertible top cover with the drivers and passenger humps? I love that look Cheers Ricky M
Rmiddleton
by Steve A » Fri 28.10.2016, 18:34
Thats a good find.
Sometimes the OEM parts are just not up to it
by tigerdog » Thu 24.11.2016, 21:57
Thanks, Phil!
by lotusflasherman » Fri 25.11.2016, 00:49
tigerdog wrote:Thanks, Phil!
You're welcome..
by Steve A » Fri 03.02.2017, 20:51
Fitted it today (at long last
) it's a bit of a wrestle to get it in but it looks like it was meant to be
Cheers Phil
by C3LOS » Sun 05.03.2017, 20:33
To help fit the seal for future LECS, try 10% fairy liquid, 90% water
C3LOS
- Tinkerer
by HJ2 » Mon 06.03.2017, 11:24
As always... top tips!
My grommet is ordered
by lotusflasherman » Mon 06.03.2017, 14:22
2nd tip is they are much easier to fit if warm and the rubber flexible. Warm day, warm garage or dunk it in hot water for several minutes ... maybe with "10% fairy liquid"
by Rusty Wishbone » Sat 18.03.2017, 20:01
Brilliant tip! I was getting engine fumes inside the car, and started looking for routes to the inlet of the ventilation system. I began by sticking duct tape around the induction pipe as it emerges from the front wing, and that immediately solved the problem. I have now installed the grommet suggested by lotusflasherman, and I now have a proper fix. I might need to drip a little silicone sealant between the pipe and the grommet so that I get a really good seal.
I actually think that this is an important safety fix to avoid breathing engine fumes.
Rusty Wishbone
by simonbuk » Sun 19.03.2017, 12:00
How does engine fumes get in via this route ?
Just bought one of these as noticed mine seems to have shrunk a bit !!
Black S2 No.357
Aqua Blue S2 No.385
simonbuk
by simonbuk » Fri 24.03.2017, 19:34
Got mine and fitted it, no water/washing up liquid needed but I guess it would have helped !!
Certainly looks a lot neater.
Black S2 No.357
Aqua Blue S2 No.385
simonbuk
by Brit-Car-Nut » Fri 24.03.2017, 22:44
Rusty Wishbone wrote:Brilliant tip! I was getting engine fumes inside the car, and started looking for routes to the inlet of the ventilation system. I began by sticking duct tape around the induction pipe as it emerges from the front wing, and that immediately solved the problem. I have now installed the grommet suggested by lotusflasherman, and I now have a proper fix. I might need to drip a little silicone sealant between the pipe and the grommet so that I get a really good seal.
If you were getting engine fumes into the cockpit, then the connector from the intake tube has probably perished. The Ventilation system is supposed to get it's fresh air from the very front of the clam and that tubing is connected to the system with a foam coupling. When the foam perishes, the ventilation system gets it's air from the area near where the induction pipe passes through the bulkhead.
It is listed here:
http://www.deroure.com/partinfo.asp?MAK ... PBID=62818A picture of where it goes is here:
download/file.php?id=22438&mode=viewThere are many suggestions of ways to replace it, but at £6.21, why struggle to make something else.
by Giniw » Fri 24.03.2017, 23:20
Mmm, that is strange, I thought the air intake was on the other side?! (RH side)
Of course my Elan is a LHD so it may be reversed.
EDIT: on second thought, that would make sense since the blower is behind the glovebox.
Giniw
Return to Picture Gallery
