Dan V wrote:I shall have a play after work tomorrow, with the dials.
But it was a brand new battery, that I have fitted to the car.
Dan V wrote: On top of this, the battery light on the dash has also come on, so will need to look into this more
Dan
with both these guys, in fact though it needs addressing now you have seen it. Dave's solution is the way I went but you'll spend all month looking for Phosphotic Acid so I'd try some Phosphoric Acid instead epipete wrote:.... but you'll spend all month looking for Phosphotic Acid so I'd try some Phosphoric Acid insteadwhich you can get from good Garden Shops or on line.
dapinky wrote: The cheapest way to get small quantities of pure (or as pure as you'll get! ~81%) is from somewhere that sells swimming pool/hot tub chemicals, Hydroponic growing stuff or fish tank chemicals... just put "ph down" into the search box on ebay (or anywhere else). It is food-grade acid which is used to adjust the ph levels in water. A little bit goes a long way as it is too pure to use neat, and the maximum strength that you ever need is 20% (and it works at far less than that).
So a 250ml bottle will make up a 2L pop bottle of useable (10%) solution, which will keep indefinitely for future use. Once you start with the stuff though, you'll be hunting round for anything rusty to dip in it just to watch the magic happen
