simonbuk wrote:Wheres my dump valve then ?
Are you sure that you're not hearing induction roar from the non-standard filter?Fredjohn wrote:The clip on the CAS appears to be ilo the missing/broken plastic lug on top of the CAS case. I can see the metal lug to screw into, but not the plastic bit or screw. .
maz_r wrote: it does need to keep the cr@p out of the gubbins
dapinky wrote:Phil,
Whilst I like the price, I can't comment on the quality......
....it's basically a knock-off version of the Forge DV007 - and the interweb is full of opinions on how good they are
tigerdog wrote:Whether it needs one is up for debate but most modern turbo installations use a variant called a Compressor Bypass Valve. The difference is, instead of venting to atmosphere, the bypass valve recirculates the air released during shifts. On the Elan, that's not critical because the fuel metering system does not measure the amount of air going into the engine; it makes decisions based on throttle position, manifold vacuum/pressure, RPM, etc. It's pretty crude by modern standards. My personal preference is for recirculation; even though it does not make a difference to fuel metering, I don't like my car to sound like some teenager's chavv-mobile.
There seem to be very few scholarly works on compressor bypass and stall/surge, especially in engines. Most of the literature is built around industrial compressors for gas pipelines, etc. I found a great PDF from a Swedish university that goes into the modelling of turbocharged systems. The maths are beyond my ability but the text is meaningful.
https://www.vehicular.isy.liu.se/Publications/MSc/05_EX_3712_CFEW.pdf
I cobbled together a cheap Chinese eBay valve a few years ago but I've never been convinced it's doing the job properly. I'm debating either going back to a TurboXS valve or using one of the Kayser units as installed on Saabs, Volvos, Porsches, Audis, etc.
