Simon_P wrote:The recommended oils are all GL-4
The wiki says
"Bottom line: 75W-90 GL-5 full synthetic gear oil." which I believe is incorrect.
tb10 wrote:Damn..... Jyst bought some GL-5 and it's now in the gearbox......do I drain it or leave it.....?
for starting this thread. He might have saved you a gearbox rebuild in the future...
I am glad I put that Castrol GL4 oil in my gearbox a year ago ^^ (except that it's the GL-4 variant, not the GL-4+ as showed on your photo)lotusflasherman wrote:Simon_P wrote:Reckon this is the current oil, and it's GL-4(+) so shouldn't eat phosphor bronze bushes and synchro hubs ..![]()
www.opieoils.co.uk/p-6363-castrol-syntrans-transaxle-75w-90-formerly-taf-x-75w-90-synthetic-transmission-fluid.aspx
Simon_P wrote:If you have clean 75W90 GL5 give it to someone who has a separate diff as GL5 is the spec for what we all used to refer to as EP (extreme pressure).
tb10 wrote:Edit..........
Just checked:
Front differential refill 0.75L (0.8 US quarts) from dry 0.8L (0.85 US quarts) Texaco S5 75W90 API GL5 or Castrol SAF X0 TYK500010 SX 75W90 synthetic
Rear differential refill 1.0L (1.1 US quarts) from dry 1.2L (1.3 US quarts) Texaco S5 75W90 API GL5 or Castrol Carbon 75W90 TYK500070 SX 75W90 synthetic
So that will be a yes then!
Fabulous
Fredjohn wrote:Yaow ay wasted it then. Oil av a point next toime we meet![]()
Simon_P wrote:Geoff (or someone else) in the "wiki changeover" this has reverted to the previous version.
Please could you amend the recommendation again.
