Yes but that wouldn't explain oil in the intakeCandles wrote:Purely on balance of probabilities, your turbo oil seal is worn and it is leaking oil into the exhaust-side of the turbo.
Good to see you back contributing regularly Candles. I always remember the early days when under Candles it used to read Fife (sure it was a small f though) Mentally I read Candles Fife whenever i read Candles... Candles Bristol just isn't the same.
Rambo wrote:Better get an Alan Elanscanman Everest chip and port the wastegate then.
And if you haven't got one yet, a Cybox (Peco) or a Piper will improve things further, particularly exhaust note in 2nd and 3rd gears. Sounds much better on overun too
Simon_P wrote:If you can take it off you can certainly do the DIY fix - See Dave Pinks instructions. The most important thing to do is mark it accurately so that you can reassemble without having to balance it.
Next job is to see what parts are still available before you undo anything else - Some of the nuts are special 1 way and break the studs if you try to undo them. Rebuilding the turbo is the simple bit.
