lotusrepair wrote:I went through what I thought was overboosting. Are you getting a check engine light on after it overboosts? The injectors should shut down if it is going over. I had a time when the gauge was going all the way and it turned out to be a bad wire connection on the transmitter. I Cleaned the terminals and the grounding point. It read correctly after that.
Yes when it goes to one bar i get a engine light and loss of power
