Lately I must have encountered a pot hole because my left front wheel is a little bent ... (I suspect the right one is not fully round either)
Anyway, I know that an alloy wheel is often repairable.
I asked for a couple of quotes and it appears it's between 80 and 180 euros per wheel (straightening+paint).
The process seems relatively simple (plenty of videos on youtube, e.g. https://www.youtube.com/watch?v=ig8qqck7has) :
- mounting the alloy on a hub so that it can be turned and measured,
- heating the wheel to soften the alloy (in french "température de recuisson", in english "annealing temperature" maybe?)
- straightening the wheel with a little hydraulic piston
The videos I have seen don't show a final quench step, so I am wondering if they are doing it at all*.
So here is my question: does anyone have any experience or knowledge about all that?
Does anyone know the alloy composition of our OZ Ruote wheels?
Thanks in advance!
(*) Incidentally I have read that the aluminium quench effect is not immediate, and that the first hour let the aluminum nearly as soft as after annealing it ... So when the aluminium forming is straightforward, one can heat it, quench it and form it cold in a single step. Rather interesting in my own opinion
