sinannasirli wrote:I did make sure that there is good ground.. Measured with multimeter... from the bracket to iback of the gauge..
It has ground.. I am going to get crazy....
Next thing i will do is to take the transducer apart.. or try with a new transducer..
MIne is an S2 car but the transducer is orange instead of grey, so somebody have messed up with it already, as they told S2 transducer is grey..
Sinan
sinannasirli wrote:İs it possible for you or for anyone else to measure the resistance between G terminal and earth of the transducer?
What is important, it shouldnt be hooked up to the gauge when measuring, at least not the G terminal..
Maybe measuring any spar s you might have?
do you have connectivity with some resistance or no connection?
Thank you
Sinan
shakadad wrote:Wow I just had my boost gauge stick up at max when turning the car on. This thread seems to have it solved, I'll go out to check that screw now.
Video of Gauge jumping to max...
