Lotus Aftersales Parts List - Newest Version
Re: Lotus Aftersales Parts List - Newest Version
Postby Brit-Car-Nut » Fri 19.02.2016, 16:50
Lotus has plenty of the HES KITs. They come with a new "harness end" plug kit since the new HES uses a different plug configuration.
Code 41 is usually caused by the HES but code 42 could be caused by a bad Ignition Control Module, dirty/corroded connections at the ICM or bad coils. There is a decent test process presented in the Closed Loop manual. Use the link below to get a copy and perform the tests described. I still have ICMs if you feel that is the cause of you error code. See my listing under New Parts for sale: viewtopic.php?f=129&t=23175.
Coils are cheap at amazon or Rock Auto. They are very common DR39 and were used by a gazillion GM models so readily available at least over here. Usually around $11.00 per coil.
Postby Giniw » Fri 19.02.2016, 17:59
I don't know if I need a new ICM yet but thank you very much for the offer and all the informations!
I could be interested in a near future! :)
Giniw
Postby John_W » Sun 03.04.2016, 15:22
Brit-Car-Nut wrote:Here is the link for Excel Format: Current Aftersales List in Excel format
Here it is in PDF: Current list in PDF format
To see the collection of Aftersales Lists I have been saving you can also go here: All of the Aftersales Lists
John,
The link to your website comes up with a message saying it is "parked" by Go-Daddy.
Postby madbilly » Sun 03.04.2016, 21:37
I found thisusing google cache search. A more intense search may find the XLS version.
madbilly
Postby Brit-Car-Nut » Sun 03.04.2016, 21:55
Sorry everyone. I changed hosting companies and had to move 15 websites and missed some files on sites I don't intend to continue.
The NEW links are:
Current List in PDF Format
Current List in EXCEL Format
All Lists in both formats
The lists are also available from my main website: http://www.lotusm100.com
It is important to know that Lotus raises ALL prices by a multiplier at least once a year, so even the "Special Price" parts go up.
If it isn't on the current list but was on an older list, then the part is now obsolete at Lotus and SJs, Matty or SW Lotus probably have the remaining stock.
Postby Brit-Car-Nut » Tue 05.04.2016, 16:36
Just received the newest price list. I have updated the listings and now you all can see the newest prices and part numbers still available.
I highlighted the M100 specific parts in Bold Blue but ALL of the Special Price numbers are listed.
Postby HJ2 » Tue 05.04.2016, 17:08
Thanks for Sharing again John!
Is it me, or is the Elan listing getting shorter and shorter? :(
Postby Brit-Car-Nut » Tue 05.04.2016, 17:14
Unfortunately, the parts are running out. They used to send me a quantity with each part number but now it is "What's on the list until it is completely out of stock". You can usually ask your dealer how many are still available, but "stocking dealers" like SJs, Matty or SW Lotus are doing the same thing and when the quantities get low enough, they can make an offer for the remaining stock at a higher discount. That means there might have been 15 pieces left yesterday but all gone today...
Buy anything you need or think you will need because it may not be there when you really need it.
Postby HJ2 » Tue 05.04.2016, 18:10
I don't want to think about it too much! :bonk:
Gives me a headache :smt010
Postby Brit-Car-Nut » Fri 29.04.2016, 19:44
I received an "interim" list that
actually has a lot of prices going UP!!!.
If you want to buy from this list, you NEED TO TELL THE DEALER YOU ARE USING THE "NEW CLUB LIST"
List in XLS Format
List in PDF Format
Postby chrisP » Thu 30.06.2016, 11:13
Does anyone know what is going on with the aftersales list. I just emailed my local dealer, with a list of parts. He looked up on the Lotus system and came back with the regular retail price on all of them. A quick check on Deroure with random part numbers from the list (M100 and non M100) and it shows everything at the normal retail price.
Best Regards
chrisP
Postby Brit-Car-Nut » Thu 30.06.2016, 12:54
Chris:
If you are referring to the very latest list, then the dealer should know there is a "Club Discount List" and he has to specify it when he places his order.
Best to just call Robert at Stratton Motors:
Robert Chapman, Parts Manager
Stratton Motor Company
Ipswich Road
Long Stratton
NR15 2XJ
Tel 01508 530491
Robert will get you the correct prices and places two orders every week, so the parts arrive quickly.
If Stratton Motors is too far away, just use a courier like P4D, Parcel2Go, Interparcel or Hermes to pick the parts up and deliver them to you. Their rates are very competitive
Postby chrisP » Thu 30.06.2016, 13:24
Thank you for the details, I pointed them to this thread but to no avail. I will get in touch with Robert instead.
Many Thanks
chrisP
Postby chrisP » Mon 18.07.2016, 11:22
As it was a bit of a pain to organise parts through Stratton, I decided to email Lotus directly, a nice chap by the name of Chris Brown got back to me, sent a copy of the list to my local Lotus dealer and and asked them to contact me. Parts are now on order.
chrisP
Postby Brit-Car-Nut » Mon 18.07.2016, 13:22
Happy to hear you got it sorted.
Postby Scott » Sun 24.07.2016, 11:56
Hello there, explain me something please, those lists are the remaining OEM Lotus Elan parts providing by who? What is the difference in blue bold letters?
Also where do we place the order or contact to?
1998 BMW 316 E36 Coupe
2001 Volvo S40 1.6
1991 Lotus Elan M100 Turbo
2004 Ducati Monster 620ie
Scott
Postby Brit-Car-Nut » Sun 24.07.2016, 12:17
Scott wrote:Hello there, explain me something please, those lists are the remaining OEM Lotus Elan parts providing by who? What is the difference in blue bold letters?
The lists are provides by Lotus UK. You order from a UK Lotus Dealer. If there are Lotus Dealers in Greece, maybe they can get the parts at the discounted price, but most won't bother.
The numbers in BLUE are "100" series parts - those are specifically for the M100 although Lotus used other parts to build the M100 as well. You should use the digital parts books to generate your wish list and then compare the part numbers to those on the different lists. The last few lists were limited stock and the prices reverted to the OLD prices pretty quickly.
Postby Scott » Sun 24.07.2016, 12:22
Well i have a lotus dealer and i should go visit him by september as i need hood/door seals and some fixings.
2001 Volvo S40 1.6
Scott
Postby Brit-Car-Nut » Sun 24.07.2016, 12:35
You are wasting your time looking for seals at the Lotus dealer. All but the "A" Pillar seals went obsolete years ago.
The "A" Pillar seals are B100V0117F (LH) and B100V0118F (RH) and they currently sell for £100.26 EACH.
Postby Scott » Sun 24.07.2016, 12:47
OK so what are we going to do for our seals?? any solutions?
2001 Volvo S40 1.6
Scott
Return to Elan Parts for Sale (New Parts For Sale)
