Wheelarch liner Pastic/Rubber?
Postby sheriff464 » Sun 21.08.2016, 20:59
Hello LEC'ers: Can anyone tell me what plastic is used for the wheelarch liners? As there are gouges and splits in several areas,where I suppose, twenty odd years of getting them off and on is bound to suffer some battle scars! (rusted rawlnuts etc,etc.) Is the plastic available to buy from any outlet at all? Any help would be much appreciated! From Sheriff 464.
sheriff464
Re: Wheelarch liner Pastic/Rubber?
Postby epipete » Wed 28.09.2016, 10:58
I shed mine the other month and have to undertake a repair to it as well, I haven't gotten around to it yet but was advised that the liner is a thermo plastic and as such similiar items are available in the scrappy. You can then repair it by using heat and welding bits together.
Postby sheriff464 » Wed 28.09.2016, 18:17
Thankyou Epipete,will go down to the local scrapyard at the weekend!
sheriff464
Postby Jeemy » Thu 29.09.2016, 18:35
Its ABS plastic.
I've got some spare arch liners, if you are short. Also, I repaired one for somebody. I bought a Power-Tec Plastic Welding kit and the only rod that took, was ABS plastic.
You'll get 20% off that kit with code LECM100DISC
It won't fill in burst-out screwholes, big fibre or rubber washers are your best bet. But it will repair cracks solidly.
T: 0800 084 3084
M: 07391 295 146
Jeemy
