Help needed re B pillar caps
Postby Justin1969 » Sat 08.10.2016, 22:18
Lotus Elan M100 SE B post caps (pair L/H & R/H) Late Style
Hello all, ive purchased a pair of B post caps but I now require the brackets and springs to attach them to the B posts. Has anyone had this problem and where did you source the brackets and springs from....if they are available??
Also re rubber seals roof and windscreen. All are okish but I do need to add/fill small areas. Does anyone know of a black rubber compound I can use to do this or any alternative?? Cant afford to replace seals until completely gone.
Thanks in advance as I know some of you Elan Guru`s will respond. Regards to all, Justin
Justin1969
Re: Help needed re B pillar caps
Postby Brit-Car-Nut » Sun 09.10.2016, 01:54
Are you sure you got the right covers for your model? There are two designs: Early and Later. They are not interchangeable.
There are no brackets or remote springs for the later style caps, just a spring that is built inside the hinges. The late style hinges are now obsolete.
The early style brackets are obsolete from Lotus but probably available from a breaker and the early springs are still available from Lotus B100U0240F for £3.09 each.
The early brackets are not excessively complicated so you could make up a set using some angled metal. Maybe someone near you will let you take some measurements so you can fab up a set?
Postby Justin1969 » Sun 09.10.2016, 17:44
Hi thanks for your reply. Yes they are correct and are the earlier version. One is still on so I can see the bracket and spring. I think I may need to make one up as you suggest.
Anyone have any thoughts on a black rubber paste/putty or something that I can use on slightly perished rubbers to fill in small areas.
thanks. Justin
Justin1969
Postby TrevorB » Sun 09.10.2016, 17:51
Justin1969 wrote:Lotus Elan M100 SE B post caps (pair L/H & R/H) Late Style
Hi Justin
I have used a rubber compound called 'SuGru' which is available through Amazon it's a bit like playdo.
Re the 'B' post caps have you tried Wayne in Bahrein his website http://elanm100.com/web-shop
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Postby Justin1969 » Sun 09.10.2016, 18:54
Thanks Trevor I will try the compound you suggest. Re caps I have the correct ones, I got them through the guy you suggest. Thank you again for the comment and advice. Justin
Justin1969
Postby Rice crispy » Sun 09.10.2016, 18:58
Justin the black rubber stuff could be as TrevorB says or sikaflex which comes in tubes like mastic and sets like rubber in the air. I've not used sugaru but have used a rubber type black stuff which never stops being sticky so is no good for seals. Sikaflex can be covered in clingfilm to mold to shape as required
Rice crispy
Postby TrevorB » Sun 09.10.2016, 19:26
Rice crispy wrote:Justin the black rubber stuff could be as TrevorB says or sikaflex which comes in tubes like mastic and sets like rubber in the air. I've not used sugaru but have used a rubber type black stuff which never stops being sticky so is no good for seals. Sikaflex can be covered in clingfilm to mold to shape as required
I have tried silkaflex but found the SuGru easier to mould.
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Postby Kathryn » Sun 09.10.2016, 21:06
I've not tried Sikaflex as it seemed wasteful for the small amount I needed but I have tried Sugru on my A pillar seals with mixed results. The first time I used it I put it on top of some previously applied silicone sealant and it worked really well and stayed in place for months before eventually falling off. I then removed all the old bits of sealant and some of the seal too (accidentally, it crumbled off!) and filled it with Sugru. This time it didn't stay stuck and sheared off when I closed the window! I've not given up on it yet though and it has stayed stuck elsewhere. Only this evening I had another go with some black sealant and plan to add some sugru when it is dry if necessary.
I've been putting off buying new seals too, but I think now the time has come.
(You can buy Sugru in Halfords btw.)
Palacio S2 #540
Kathryn
Postby Justin1969 » Sun 09.10.2016, 21:40
Thanks for your replies and alternatives. Ive just ordered some sugru from amazon and will give it a go. Yes ive been putting off buying seals etc but fear I will have to sooner rather than later. On that point, does anyone know where to purchase them and any ideas of cost...do I need to remortgage the house for them ?? Justin
Justin1969
Postby Justin1969 » Sun 09.10.2016, 21:43
Just read you can buy it in Halfords,i will remember that the next time I'm back in the UK, thank you. Justin
Justin1969
Postby Brit-Car-Nut » Sun 09.10.2016, 23:17
Justin1969 wrote:Thanks for your replies and alternatives. Ive just ordered some sugru from amazon and will give it a go. Yes ive been putting off buying seals etc but fear I will have to sooner rather than later. On that point, does anyone know where to purchase them and any ideas of cost...do I need to remortgage the house for them ?? Justin
Most ALL of the seals are now obsolete. Lotus still offers A-Pillar seals at £100.26 each. I believe SJs have S2 header seals and SW Lotus has some of the stowage cover and boot seals. I don't know anyone that is offering falling pillar or intermediate seals now but they are all very dear and a remortgage might be needed.
Return to General
